eng swap
Old 04-11-2011, 08:48 PM
axel 56's Avatar
axel 56
axel 56 is offline
eng swap
I picked up a replacement eng for my truck 94 idi e4od 4x4 estcab I was wondering if I can grt the eng out if I leave the exhaust manifolds in truck just unbolt from the heads and if there are other isuse with this swap its a 93 7.3 eng off of a standerd trans. Any info would be apprecated Thanks
Old 04-11-2011, 09:29 PM
BlueOvalBud's Avatar
BlueOvalBud
BlueOvalBud is offline
I don't see why you couldn't...
Do the studs on the manifolds look like they'll break?
You might have a fun time trying to get in there to loosen the bolts, but if you pull the inner fender, you should have plenty of clearance.
Old 04-11-2011, 11:24 PM
1994F2507.3L's Avatar
1994F2507.3L
1994F2507.3L is offline
i have to ask why do you want to leave the manifolds? just unbolt the exhaust pipe ( i think its only 2 bolts) trying to remove all the bolts/studs whatever.. from the engine with it in the truck is going to be an unnecessary PITA they've been on there nearly 20 years they aint gonna come without a fight.....
Old 04-11-2011, 11:36 PM
axel 56's Avatar
axel 56
axel 56 is offline
The reason I ask is the eng I bought the studs broke when they tryed to take them off so I thought that I might leave them on the exhaust and take the manifolds off It was just a thought cause I havent realy looked at it yet wont realy look till wedsday I am all about the easyest way LOL
Old 04-11-2011, 11:47 PM
1994F2507.3L
there is very very little room down by the manifolds.... much easier just to unhook the pipe from the manifolds and remove the manifolds when its out of the truck and you can get a impact to them.remember this is the biggest engine (besides the 7.5) you can get in these trucks there's not much room lol especially compared to the 302 they put in a few 3/4 tons lol
Old 04-12-2011, 10:04 AM
IDI Diesel's Avatar
IDI Diesel
IDI Diesel is offline
I pulled two 7.3's and itd be much easier to unbolt the exhaust flanges than trying to take the manifold off. Save yourself the aggrivation. Once you pull the motor you can spray lotsa PB blaster on the bolts
Old 04-12-2011, 11:17 AM
BlueOvalBud
I've had manifold studs break off many times, so I understand why you don't want to touch those bolts.
Usually we end up drilling out the broken stud, and then doing a bolt and nut setup instead of a stud.
I think you'll have better luck just snapping the studs off and pulling the engine. Then with the engine out, you can hit the manifold bolts with PB Blaster and carefully get them out without breaking one.
Then you'll be able to drill the manifolds out conveniently on the workbench, or bring it to a machine shop where they could drill it out and put another stud in there.
Old 04-12-2011, 07:15 PM
axel 56's Avatar
axel 56
axel 56 is offline
Hey thanks it was just a thought . Will be starting on it next week probly change rear maine seal before I put eng in looks like its on a plate that unbolts do I need a speacil press for this?
Old 04-12-2011, 10:43 PM
BlueOvalBud
I don't know about the Rear Main, you may want to start a new thread for that.
Start soaking everything with PB Blaster NOW!
Old 04-12-2011, 10:58 PM
84-6.9L's Avatar
84-6.9L
84-6.9L is offline
Take that plate off, you will need the plate gasket, pull the old seal out of it, tap the new one in the new seal should come with a plastic sleeve to put over the crank so the seal slides on correctly, and it may also tell you not to oil the new seal if its the fel-pro like i got
Old 04-13-2011, 03:21 AM
greywynd's Avatar
greywynd
greywynd is offline
I think that you would find the oil cooler will hit on the manifold. Drop the y-pipe, and pull it with the manifolds on.
Old 04-13-2011, 11:44 AM
axel 56's Avatar
axel 56
axel 56 is offline
Thanks guys much appreceate to info will post on how it goes and if I got the shaft on the eng hopefully not and it all works well the truck will be fore sale wen done
Old 04-13-2011, 08:44 PM
BlueOvalBud
Where abouts are ya? I enjoy beating on IDI's and making money in the process
Old 04-13-2011, 08:56 PM
IDI Diesel's Avatar
IDI Diesel
you dont need anythingspecial for the rear main seal. its a ew bolts. I replaced mine with the engine out witha one piece seal
Shane Carruth
01-05-2015 07:16 PM
rgoodell
12-24-2012 08:08 PM
rbaker
Escape & Escape Hybrid
05-23-2011 02:56 PM
hotfordmomma74
Missouri Chapter
06-28-2006 03:05 PM
JAMESR
02-21-2006 10:12 AM
Quick Reply: eng swap
