8.8 LS carrier vs, open carrier. Same thing???
They will exchange, but I'm sure they're different. At least, the LSD carrier has the notches or splines inside that engage ears or splines on the clutch packs. I've never opened an open 8.8 diff before, but I would guess that it does not have those notches.
You can let the LSD's clutches get really worn out and turn it into an essentially open diff with very sloppy axles. You can also turn an open diff into a locker by installing an aftermarket locking mechanism. But I don't think you can turn one into the other by adding or removing clutches.
BLDTruth
06-15-2017 01:29 PM
86f150step
01-10-2017 08:28 AM
mando jake
1999 to 2016 Super Duty
13
03-24-2008 08:13 AM
mooktank
09-29-2003 11:40 AM
