'94 F150 8.8 trac-loc gear change - new carrier?
Changing gears on the rear end of a 1994 F150 with 3.55 gears and the factory trac lok limited slip. Going to 4.11 gears and rebuilding everything while I am in there with all new bearings, clutch packs, and spider gears. Do I need a new carrier as well for the 4.11 gears? I am getting mixed messages from a few different mechanics.
I know you have to change the carrier on the dana 44 going from 3.55 to 4.11, but everything I have read about the 8.8 says the same carrier should work.
Thanks in advance.
Thanks in advance.
Dan92
03-09-2011 11:47 AM
