Will a Dana 60 carrier fit into the Dana 50 housing?
03-21-2008, 10:48 AM
on
specifically 2002 f250 SD
I have heard that they are the same housing.
03-21-2008, 10:56 AM
No, internally they are different.
If it's a 2002 are you sure it doesn't have a D60?
Some early 02s had the D50.....then they switched to the D60.
03-22-2008, 07:20 AM
on
03-22-2008, 12:02 PM
NO Way, it's closer to dana 44
03-22-2008, 02:12 PM
on
I would like to know what exactly is different. Are the carrier bearings the same size?
03-23-2008, 11:09 AM
Pinion length is different, pinion size is smaller D50, pinion spline count is different, Ring gear is is smaller on the D50.
03-23-2008, 03:22 PM
Quote:
My question is: what's the same ?
03-23-2008, 03:27 PM
Quote:
The weight!!!
03-23-2008, 10:36 PM
Diff cover is the same, knuckles, outers, ball joints, etc are the same.
Inner shafts are different.
03-23-2008, 10:50 PM
on
Ok so would a D60 carrier and pinion go into the housing? I think on powerblock tv Jesse and Ian said that the only way to tell the difference is by opening it up.
03-23-2008, 10:56 PM
A D60 carrier, ring and pinion, etc... will only go into a D60 housing.
You can run the BOM to know if it's a D60 or 50. Or measure from the flange where the diff cover sits to the end of the pinion snout......60 and 50 lengths on the housing are different there. I don't have the specs.
03-23-2008, 11:24 PM
on
What i really need to know is what is the part # for the magic wand that will make it work?
03-24-2008, 07:28 AM
Why not just run D50 internals if it is a D50 housing?
I've hooked up to a stuck 40ton semi (I run 38s and 4.56s) and didn't break anything in my D50.
Or just buy a D60 if it's that big of a deal.
03-24-2008, 08:13 AM
D50's are pretty strong. In 4 years I only heard of maybe 2 or 3 breaking on the forum.
Unless you want more options for lockers or LS'S. Get the whole axle...
Dick
GeneGregory
06-15-2015 09:36 PM
Plowingking
12-03-2013 06:37 PM
hess_tj
22
02-09-2009 08:19 PM
fordinmudd
Offroad & 4x4
04-01-2005 12:00 PM
rancherman84
01-06-2004 09:27 PM
2001 ,
50 ,
60 ,
carrier ,
dana ,
dana50 ,
dana60 ,
fit ,
ford ,
housing ,
internals ,
pinion ,
sd ,
weight
