Fuel Pump Relay on 1989 F150
Old 03-30-2011, 06:56 PM
Thunderbird Mike's Avatar
Thunderbird Mike
Thunderbird Mike is offline
Hi,
Just bought an '89 F150 with a 4.9 automatic. The previous owner told me it needs a fuel pump relay. Can anyone tell me where it is located? I found a block with wiring running to it behind the breather in the driver's side fender wheel well. Is this is it, and if so, how do I access it? If not, I would surely appreciate someone letting me know!
Thanks!
Old 03-30-2011, 07:24 PM
tdcarter72's Avatar
tdcarter72
tdcarter72 is offline
On the 5.0L the Fuel Pump Relay is located under the plastic shield at the air cleaner support bracket.
I am not sure if the 4.9 is in the same location or not, but it might be.
Hope this helps.
Old 03-30-2011, 09:18 PM
Thunderbird Mike
Thanks, I'm sure it will!
Old 03-30-2011, 10:13 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,172 Likes on 926 Posts
Check out this thread: https://www.ford-trucks.com/forums/8...ump-relay.html Post #6 Our friend subford has some info and pics.
Old 03-31-2011, 06:30 AM
Thunderbird Mike
Thank you! This confirms what I thought. Now I just have to figure out how to access it. Does the relay just unplug? Thanks again!
Old 03-31-2011, 08:03 AM
rla2005's Avatar
rla2005
rla2005 is offline
It is a tight fit, but yes the relays just plug in. I find they are tough to remove. Maybe someone else has a "trick" to getting them unplugged a little easier?
Old 03-31-2011, 12:25 PM
Thunderbird Mike
Thanks for all your help!
Old 03-31-2011, 01:53 PM
rla2005's Avatar
rla2005
rla2005 is offline
Welcome to FTE
Old 03-06-2012, 05:27 PM
j1msevier's Avatar
j1msevier
j1msevier is offline
Fuel relay swi
It is behind the air cleaner under a black holder and it is the green one (if it is not after market) and the easiest way I have found to pull them out is with a small flat head screw driver or a flat feeler gauge slid up the side of the relay. Facing the vehicle the clip should be on the right side and they are not easy to pull out.
Old 03-06-2012, 06:39 PM
rla2005's Avatar
rla2005
rla2005 is offline
Thanks for the info, but this thread is almost 12 months old.
Old 03-07-2012, 07:07 AM
Thunderbird Mike
Thanks for all the info. You will all be happy to know that I have successfully replaced the relay. Thanks again!
landscaper62
1999 to 2016 Super Duty
19
05-11-2019 03:11 PM
nomad27
Modular V10 (6.8l)
23
03-03-2019 02:55 AM
docergo
05-06-2018 09:15 AM
dakota-boy
Electrical Systems/Wiring
03-14-2016 09:29 AM
Shut_It_Down
1997 - 2003 F150
05-27-2012 04:46 AM
Quick Reply: Fuel Pump Relay on 1989 F150
