2002 F250 Fuel Pump Relay
For all who are interested, I found the relay for the fuel pump. There are 2 junction boxes located on the driver's side wheel well under the hood. The box closest to the fender has the fuel pump relay in it. There are 2 'small' relays. THe one closest to the fender is the fuel pump, the other is for the parking and tial lights. The relay number is F57B-14B192-AA. It ended up being the fuel pump.
It appears that the relays mentioned are NOT fuel pump relays. It seems some thoughtful, careful experienced members here have ruled out the above post. Beware.
https://www.ford-trucks.com/forums/1...t-running.html
crank no start
there has been no codes ....truck started ran about 3-4 seconds and has not started since. to date: replaced fuel pump,fuses, fuse box, checked fuel pressure..good...checked spark,....good.. checked compression ,...good ....truck in shop mechanic is lost ..not an electrical or computer problem as far as he knows....but i would think the three components to run would be SPARK..FUEL..AIR... we got 2 out of 3 it has to be an air issue correct???????? any help would be greatly appreciated so i could relay this to the mechanic !!!!!!!! thank you
landscaper62
1999 to 2016 Super Duty
19
05-11-2019 03:11 PM
1970moose
03-26-2017 11:36 PM
theRedEx
20
09-06-2016 01:36 AM
