What started out as an oil change, turned into a radius arm bracket relacement. 2 weeks later, the other one gave out.
Driver's side was riveted, pass side bolted.
This suggest that the driver-side was still the factory bracket, but the passenger-side had already been replaced at some point in the past.
Originally Posted by IDIDieselJohn
Wow, first time I see that!
Same here. Lotsa weird issues with these trucks lately it seems, remember the guy whose I-beam split where the bushing goes in? Now how does THAT happen, even more so with a good bushing in there?
Does anyone have a good write up or can tell me how to replace these bushing. I believe you have to take the bracket off, replace the bushings then put the bracket back on with some grade 8's?
Yep, that's how you do it. I've heard you can pull the front-end out, but I'm not sure about that. I do know you CAN NOT use a come-along to pull one side out... I ruined half the threads on my pass. radius arm trying to avoid taking the rivets out and had to put the original bushing back on for now.
