2wd or 4wd?
When I did them on my F100 2wd I dropped the whole i-beam out to replace the radius arm bushings plus I did the pivot bushings on the i-beams also.
On my Bronco(4wd straight axle) I blocked up the body then removed the radius arm nuts on both sides and was able to push axle forward enough with my foot to get in the new radius arm bushings.
It really is not all that difficult, once you remove the nut and take the back bushing off, you can use a cumalong to a tree and pull the axle far enough forward to replace that bushing without taking the bracket off, at worst you might have to take the both through at the coil spring off, as per your other question, the truck is perfectly safe to drive like that, you may get some noise, and yes you could just replace the one bad outer bushing, that would be the easy way out but the kit should come with all the parts needed to do one side
You grind the rivets off to drop the bracket. To replace the bushings you remove the large nut at the end of the radius arm. Then you remove the bolts (or rivets) holding the bracket to the frame. Remove old bushings and replace, bolt bracket on, then tighten the large nut on the radius arm.
If the bushing goes completely out, it will cause a 'popping' sound as the radius arm bangs against the bracket. This will cause the steering to be a bit sloppy and cause extra tire wear. Eventually it will destroy the bracket and radius arm,too.
If you want to remove the front springs, I've always just jacked the frame up until the front tire is just barely clear of the ground, then removed the spring. It will be fully extended, so no tension will be on it.
Your truck should not have ball joints unless its 4WD which it doesn't look like, you can lay under the truck and have someone turn the steering wheel back and forth and see where the slop is, you probably need a steering box as these trucks commonly do
WOW, you guys are doing it the hard way!
1) Raise truck(1 side at a time), support on stands,remove front wheel.
2) remove lower shock bolt
3)put floor jack under I-beam,raise up to take tension off radius arm,loosen radius arm nut and remove rear bushing.
4)remove upper coil spring retainer from spring bucket(the coil spring will not come flying out as it is bolted to the I beam on the bottom)
5)lower floor jack,slide radius arm out of bracket and remove bushing.
6)install new bushings/radius arm/coil spring retainer/lower shock bolt in reverse order...noting the direction of the washers on the bushings.
7)tighten radius arm nut all the way down,install wheel and torque nut down to "I THINK" 200ft lbs...double check that.
8) lower vehicle and do other side the same way. Will take you the better part of the afternoon for your first time....you will get faster at it the more times you do it(for other trucks)
I was told by my ford dealer that the upper and lower ball joints need to be replaced.
How do I tell what is worn on the suspension causing wondering?
It wont hurt it if I just do the driverside? The passengerside looks fine.
Is it 4WD, I think you have King Pins, I could be wrong though, you should be fine just doing the side that is fine, the parts are cheap though and if it was me I'd do both sides, like I said lay underneath and watch the steering while someone jerks the steering wheel back and forth, it should all move together in unison, you will notice where the slop is if the truck has some
