Front Axle Pivot Drop Brackets
Old 03-10-2011, 01:47 PM
USMC35thSS's Avatar
USMC35thSS
USMC35thSS is offline
I recently purchased axle pivot drop brackets from BroncoGraveYard and am having issues with the installation. I was able to get the one that bolts into the drivers side however the passenger side doesn’t line up with the bolt holes. Has anyone installed this kit before? Its Front Axle Pivot Drop Brackets, 4-6" Lift Item #33514 1980-96 Ford Bronco 1980-96 Ford F100/150. I own a 95 F150 4X4. Thanks<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old 03-10-2011, 02:44 PM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
I'm going to assume that these are the Superlift drop brackets.
I'm a bit confused b/c there is a couple ways to look at this. Which bracket are you working on? The on physically on the passenger side of the truck with 4 bolts(holds driver side beam) or are you working on the driver side of the truck(holds the passenger side beam)??
I had no problems with my drop brackets. The one on the passenger side(for driver side beam) bolts in using factory hardware. The driver side(for passenger side beam) you have to drill 2 holes in the bottom of the crossmember for the bracket to bolt up. It uses only one of the factory bolt holes.
I can get you pics of mine if needed.
Old 03-10-2011, 03:11 PM
USMC35thSS's Avatar
USMC35thSS
Thanks for the response. The way you explained it was perfect. I had no idea I had to drill any holes and that’s why I was confused. Pictures would be great. Thanks again!
Old 03-10-2011, 03:22 PM
strokin'_tatsch
Use this pic til I can get you a better pic.
Old 03-10-2011, 03:39 PM
strokin'_tatsch
Also, check out this document. It might help a little bit. http://www.superlift.com/instructions/1000.pdf
Old 03-10-2011, 04:17 PM
USMC35thSS's Avatar
USMC35thSS
That bracket is pretty close to the one I have. The one I have doesn't have the two holes lined up like yours. They are staggered.
Old 03-10-2011, 05:42 PM
strokin'_tatsch
Yours should mount the same as mine though, yeah??
Old 03-10-2011, 06:30 PM
USMC35thSS's Avatar
USMC35thSS
I would think so. The kit didnt come with any kind of instructions or template for the drilling so im just going to make one. I just wanted to make sure drilling was involved and it wasnt just bolt in. Thanks again for your help.
Old 03-10-2011, 06:55 PM
strokin'_tatsch
I didn't use any kind of template for mine. Just bolted the bracket in there with the one stock bolt, lined it up how it needed to be and drilled the 2 holes that needed drilling. I did have to use a 90* drill b/c my drill wouldn't fit in there straight. PITA, but got the job done.
Old 03-10-2011, 07:29 PM
USMC35thSS's Avatar
USMC35thSS
Awesome I'm going to try it out tomorrow and see how it goes.
Jdeere4cm
01-09-2022 10:39 AM
1Aauto
Vendor Specials, Discounts, Product Announcements & Group Buys
03-27-2018 11:53 AM
mouks
02-09-2017 06:55 AM
axelgawn
Georgia Chapter
03-05-2016 06:20 AM
sandman3510
07-22-2004 03:36 PM
Quick Reply: Front Axle Pivot Drop Brackets
