First CEL
Old 04-18-2012, 05:40 PM
KC8QVO's Avatar
KC8QVO
KC8QVO is offline
First CEL
I'm not sure what it is yet. I need to get the truck in for a look, and the PCM/NOX calibrations. I got to work without it on and went out around lunch time and it came on.
I just changed the oil (yesterday) and added DEF (late last week), not sure if that has anything to do with it. I did re-set the oil meter/timer thingy back in the menu.
Old 04-18-2012, 05:46 PM
2ndStroke's Avatar
2ndStroke
2ndStroke is offline
Ive had two already. 1st was for a bad air mass sensor. 2nd was for a bad nox sensor.
Old 04-18-2012, 06:05 PM
Tom's Avatar
Tom
Tom is offline
Subscribed! Very curious to see what the problem is. No drivability problems?
Old 04-18-2012, 06:08 PM
ruschejj's Avatar
ruschejj
ruschejj is offline
My air sensor on the intake tube by the filter housing comes loose sometimes when I bump it. I get the CEL and I seat the plug, CEL goes away.
Hopefully same for you. It's an easy one to bugger up.
Old 04-18-2012, 08:47 PM
KC8QVO's Avatar
KC8QVO
KC8QVO is offline
Bingo! False alarm.
I popped the wire off to look at the air filter and forgot to plug it back in. It hit me while I was in the shower what it was.
On a side note, the meter thingy for filter restriction doesn't show anything but the filter doesn't look too clean. I may go ahead and replace it. I'm at 20,000 miles.
Old 04-18-2012, 09:18 PM
Tom's Avatar
Tom
Tom is offline
Lots of folks do that, but I always wonder why. If nobody is going to use the filter restriction gauge why do they even put it on the truck? Not to be difficult or anything, but just like engine oil the simple appearance of the filter means very little. The filter could be as black as your tire and if it's still filtering and moving enough air it's still just fine.
Old 04-18-2012, 10:32 PM
shadowSVT's Avatar
shadowSVT
shadowSVT is offline
I think that goes back to the huge filters they put on the 7.3's and the 6.0's - they could hold pounds of dirt and still work correctly. The housings were a PITA to open, so the meter helped.
Old 04-19-2012, 07:37 PM
JReinert's Avatar
JReinert
JReinert is offline
I was the same way with the couple of 6.0's I had. I changed the air filter every 100k if it needed it or not. It was amazing how long they lasted. With the 2011 the longest I could stand to have it in there was 30k miles and at 15 bucks, I changed it anyways.
Old 04-22-2012, 09:13 AM
KC8QVO's Avatar
KC8QVO
KC8QVO is offline
Just a quick note on the CEL with the cable on the air intake off -
It took my CEL a long time to go back off. I re-set the connection after the light stayed on and the next day it was off. It isn't something that goes off as soon as you plug the connector back in.
Old 04-22-2012, 09:17 AM
Tom's Avatar
Tom
Tom is offline
I just realized that I had the same thing about a year and a half ago. I was reading the manual and followed the instructions to disconnect the sensor and forgot to plug it back in. I started the truck to drive to town and saw the CEL, and when I got home I scanned it and immediately knew what was wrong.
Do you have a scan tool, Steve?
Old 04-22-2012, 09:47 AM
KC8QVO's Avatar
KC8QVO
KC8QVO is offline
Not for this truck. I have a diablo sport predator I used with my silverado, but I don't believe it will read anything off the super duty.
Old 04-22-2012, 12:00 PM
Tom's Avatar
Tom
Tom is offline
It's probably read generic codes, which is what this CEL likely was. If you want something more capable I highly recommend AutoEnginuity. I'll bring mine in June if you want to check it out!
Old 04-22-2012, 12:13 PM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
I wouldn't mind checking it out if you can bring it along!
My BT ODB connector and the Torque app work great but I'd like to dig a little deeper into the truck.
Old 04-22-2012, 12:17 PM
Tom's Avatar
Tom
Tom is offline
Sounds good Matt, I look forward to it!
adambomb
11-27-2010 05:11 PM
WillFargo
01-25-2010 12:23 PM
ngng
03-17-2009 07:58 PM
00F-350 stroker
10-16-2004 09:58 PM
abendx
1999 to 2016 Super Duty
04-09-2002 07:17 PM
Quick Reply: First CEL
