2011 F-250 TPMS
2011 F-250 TPMS
Took delivery of my new 2011 F-250 last night. Got it home and was just checking everything out and noticed my truck does NOT have TPMS. Not that I care because I am capable of monitoring my tire pressures, but isn't the system mandated by federal DOT? I thought all vehicles had to have it. Has anyone else come across this?
Yeah... how do you know you dont have it? Only way I'd know is to pull the tires off to see if its got the sensors but I assume you didnt do that! Or other way air a tire down to around 55# assuming your not going to haul anything, it should go off after you drive around.
On my 09 (which is just a XL without much options) had to have it, no way not to according to dealer but free. And it didnt show up on the window sticker.
I'm assuming it doesn't have it because it has the metal/rubber valve stems. You can move the valve stem if you push on it. All the TPMS system I have encountered have rigid mounted stems/sensors. I work on cars equipped with them everyday so I know what to look for. Ford may use a different style sensor. I will try and air down a tire to see if the tire light comes on.
Thanks for the replies.
Dave
Dave
what he said
theoldwizard
05-13-2016 02:12 PM
Firewiz
1999 to 2016 Super Duty
10-08-2013 08:12 AM
