transnission problem
Hi. I have 2004 f-350 6.0l with 115.000 milles. couple days ago my truck stalled on hiway and after pulled over and re start my truck I noted transmission has no gears R,D,3,2,1, nothing.My tow haull light was flashing. towed to the shop and hooked up my AE.found codes p0770 shift solenoid E module transmission, p0703 torqu conv. brake swith B circ, p1397 variable timing solenoid B circ. low input. trouble shooted and foud broken wire from PCM to solenoid E.repaired wire and re test system no codes and tow haull light stop flashing,but no gears.swaped PCM form my f-550 no help. hooked up gauge to the line port to ck. line pressure. line pressure shows 0 psi P,R,D,3,2,1. replaced solenoid body still no help.Know Iam at @ $900.00 in minus for repair and my transmission is not working. I suspect pump or somting is broken in side.
any ideas...................?? Please help
THANKS
THANKS
send the trany to suncoast transmission and have them rebuild it with quality parts and put in a real filter in line . There is another transmission co. out there but cant remember the name but they put in better parts. My dealer told me they don't put in line filters till you bring them back for a rebuild . I told him thats stupid it a $4,000 trany.
Joseph D. Kendall
01-12-2016 07:54 AM
VX-23 Hokie
04-10-2012 11:20 AM
