transnission problem
Old 02-17-2011, 05:40 PM
cricketmowing's Avatar
cricketmowing
cricketmowing is offline
Hi. I have 2004 f-350 6.0l with 115.000 milles. couple days ago my truck stalled on hiway and after pulled over and re start my truck I noted transmission has no gears R,D,3,2,1, nothing.My tow haull light was flashing. towed to the shop and hooked up my AE.found codes p0770 shift solenoid E module transmission, p0703 torqu conv. brake swith B circ, p1397 variable timing solenoid B circ. low input. trouble shooted and foud broken wire from PCM to solenoid E.repaired wire and re test system no codes and tow haull light stop flashing,but no gears.swaped PCM form my f-550 no help. hooked up gauge to the line port to ck. line pressure. line pressure shows 0 psi P,R,D,3,2,1. replaced solenoid body still no help.Know Iam at @ $900.00 in minus for repair and my transmission is not working. I suspect pump or somting is broken in side.
any ideas...................?? Please help
THANKS
Old 02-17-2011, 07:57 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,599 Likes on 1,072 Posts
When pressure is zero either the pump drive shaft or the pump has failed. As you learned solenoids can cause the wrong pressure, but not zero pressure.
Old 02-18-2011, 12:48 PM
cricketmowing
thank you for replay. before I towed the truck to the shop it was at ford dealer and they told me I have to replace solenoid body and start from there. they what @ $1500 for that.if that does not fix than I looking anywhere between $2000 to $ 4000.for repair.
Old 02-18-2011, 01:45 PM
ljutic ss's Avatar
ljutic ss
ljutic ss is offline
A reman. Motorcraft 5 speed is around $2,500 with a 75,000-100,000 3 year warranty.
Old 02-18-2011, 06:24 PM
cricketmowing
Monday I am going to pull transmission down and take on part to see what is wrong
Old 02-19-2011, 10:13 AM
Mich6.0's Avatar
Mich6.0
Mich6.0 is offline
send the trany to suncoast transmission and have them rebuild it with quality parts and put in a real filter in line . There is another transmission co. out there but cant remember the name but they put in better parts. My dealer told me they don't put in line filters till you bring them back for a rebuild . I told him thats stupid it a $4,000 trany.
Old 02-19-2011, 11:30 AM
cricketmowing
do you know location of suncoast repair places??
imprezaguy02
08-13-2016 01:07 PM
Hq254xp
1999 to 2016 Super Duty
06-03-2016 06:42 PM
Joseph D. Kendall
01-12-2016 07:54 AM
danktank
18
03-22-2014 12:52 PM
VX-23 Hokie
04-10-2012 11:20 AM
Quick Reply: transnission problem
