Recently picked up a 2004 Ex 6.0L. Drove great for a bit, then it started shift badly, then finally the Tow/Haul light came on.
The original codes were P0976 and P0755. P0755 being shift solenoid B, and the P0976 being SSB Control Circuit low. I replaced Solenoid B and that code went away.
P0976 stayed with no change in how the truck drives. Replaced the internal harness today, and again no change.
At this point I'm at a loss. I'm wondering if it's something between the PCM and the transmission?
Most harness issues are in the harness from the PCM to the trans, not in the internal harness. The wiring for solenoid B needs to be electrically checked between the PCM and the trans.
Thanks Mark! Disregard the message I sent you. Thanks for replying here.
Does anyone have a TPS for this? Or a walk through?
Have not seen an acronym called TPS. What are you looking for?
I have access to the books and should be able to post a diagram and the pinpoint testing.
