75 super camper special rear gas tank???
Old 02-13-2011, 11:07 AM
richccc39's Avatar
richccc39
richccc39 is offline
I have a 75 super camper special with a rear poly tank, It leaks and I have repaired it several time and now it's time for it to go. I can not fine a tank that would fit any where. I would like to find a metal tank.
Old 02-13-2011, 12:02 PM
bucks77ford's Avatar
bucks77ford
bucks77ford is offline
You probably won't find a new one because your truck has the narrower frame. What I would do is take some measurements of your opening and look at websites like gastanks.com and see if you can find a tank that's narrow enough to fit your opening. I know on the highboys (narrow frame) people have used Bronco II tanks. And the other option would be to get a new tank for an F series truck and see if a welding shop could cut out a section and then reweld it making it narrower, but you'll probably end up spending much more than just trying to make a tank work.
Old 02-13-2011, 12:06 PM
79 f350ts's Avatar
79 f350ts
79 f350ts is offline
all the steel tanks ive found (lmc,denis carpenter,bronco graveyard etc.) are too wide for our trucks narrower frasme rails. the bronco tanks are narrower, but not sure of fitment issues. maybe call bronco graveyard to see if their tank fits or someone here might know. the bronc tank looks like it would fit but i cant say for sure as i havent tried one. sorry couldnt be more help
Old 02-13-2011, 04:54 PM
Sleepy445FE's Avatar
Sleepy445FE
Sleepy445FE is offline
I don't think any of JBGs tanks fit the narrow frame. You can use the 23gal bronco II tank. I'm looking for a new rear tank myself, and this seems to be about the only answer besides getting some custom tank from aerotanks or the like for big $$.
Old 08-10-2012, 03:06 PM
srshll's Avatar
srshll
srshll is offline
tank
Has anyone found a tank that will work Thanks
Old 08-10-2012, 08:36 PM
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
25, 31, and 40 gallon suburban tanks.
Old 08-11-2012, 02:58 AM
srshll's Avatar
srshll
srshll is offline
chevy
chevy stuff in a ford, whats the world coming to... But does it really work, and what are the dementions thanks
Old 08-11-2012, 07:16 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by richccc39
I have a 75 Super Camper Special with an aft axle plastic tank, It leaks and I have repaired it several time and now it's time for it to go.
I cannot fine a tank that would fit anywhere. I would like to find a metal tank.
There were two different plastic fuel tanks originally. If the truck was sold new in CA .. it has Evaporative Emission.
Note: Ford dropped "Super" from the name after 1976.
D3TZ-9002-V .. Aft Axle Fuel Tank-Plastic-20 gallons / Obsolete
1973/76 F350 Super Camper Special & 1977 F350 Regular Cab Camper Special without Evaporative Emission.
D5TZ-9002-C (replaced D3TZ-9002-Y) .. Aft Axle Fuel Tank-Plastic-19 gallons / Obsolete
1973/76 F350 Super Camper Special & 1977 F350 Regular Cab Camper Special with Evaporative Emission.
No Ford Dealer or obsolete parts vendor has either one.
Old 08-11-2012, 01:10 PM
srshll's Avatar
srshll
srshll is offline
thanks for info
Thanks for the info, so I guess the plastic tank that is all cracked and leaking is the factory tank, So then what do we do to replace it?
Old 08-15-2012, 10:48 PM
AerostarDad's Avatar
AerostarDad
AerostarDad is offline
Maybe install a mid-ship tank and don't use the aft tank at all?
Old 08-15-2012, 11:49 PM
hillbillyk's Avatar
hillbillyk
hillbillyk is online now
look for a rear tank from an f-superduty, I think they started in 88, and went up till 97, they have the same rear tank size as the super camper special. Also share the same skid plate. You can also use a rear tank from a f-350 cab and chassis dually up to 97, they share the narrow frame with the crewcabs, highboys, and f-350 camper/super camper specials. The f-350's also have the crossember that will bolt into the older trucks to add this tank, and the same skidplate as the f-superduty. the f-superduty crossmember is to wide to use. The filler neck is a little different, and I look for the earlier tanks with the idi diesels as they don't have a pump in the tank.
These poly tanks bolt right in and fit with no mods, mabye drill a few holes in the frame for the crossmember if you did'nt have a rear tank in your tuck. My buddy has this tank in his 78 f-350 he is restoring, and I put one in my 75 f-250 4x4 i'm restoring.
75MYWAY
10-25-2022 09:27 AM
Justin73supercamper
02-15-2019 08:25 AM
MATTwGrandpas77
Ford Truck Parts for Sale
05-22-2017 10:37 PM
eradicator006
08-05-2016 11:03 PM
rjonesboy
08-04-2016 06:43 PM
Quick Reply: 75 super camper special rear gas tank???
