1979 460 LEAKING INTAKE MANIFOLD??
Get some good degreaser and clean the area thoroughly. Inspect the area to make sure that you didn't miss any areas, or atleast moke note of them. Run the vehicle, then inspect for fresh oil. You may want to purchase a mirror.
Not very high tech, but it works well.
The 460 manifolds are extremely heavy as far as intakes go, it is real easy to have the rear portion of the intake gasket slide out of position and leak.
The sender is the little tin can looking thing nestled at the back of the intake manifold.
(sorry for the crappy cell phone pic)
<a href="http://www.flickr.com/photos/24183730@N03/2341398064/" title="IMG_1903 by Jim_Urrata, on Flickr"><img src="http://farm3.static.flickr.com/2230/2341398064_eee3888e15.jpg" width="375" height="500" alt="IMG_1903" /></a>
Just replace the sender, if it's leaking.
on
Leak
The top left transmission bolt goes all the way through the block into the area below the intake. Sometimes they leak. Take out this bolt and seal it with teflon tape and reinstall it. More likley your leak is the sending unit and I sure as heck would not replace the intake manifold to solve this minor problem. IMHO!
beest
01-21-2017 05:22 PM
DrZoom
20
12-22-2016 09:13 AM
Ronnief150man
04-17-2016 06:45 AM
johnson2007
04-26-2011 01:21 PM
