what is the bloody difference between the 95 f150 5.0l and the 96 f150 5.0l everything i see goes up to 95 but they changed the style in 97 why make such a huge difference can anyone explain this to me.
Oh yeah. As long as you don't have the next gen body, and I assume you don't because your not a dunce, the parts switch out. They just can't label the 95s as interchangeable because they changed 150s half a year before the 250s and 350s. If they look the same, they are.
as long as were not talking about engine stuff, you are safe. most of the engine stuff is interchangeable as well, but as conan said, yours is OBDII and the 95 and older are OBDI
well i bought some ford racing headers that are said to fit up to 95 but they look like they should fit my truck i am just having a hard time finding a y-pipe to hook up to it since mine is shot
1 year is the difference.....just kidding, check out jegs, I think they have the y pipe that will work. Mechanically should be the same as 95, but it is nice to be able to plug in a code reader to get codes on obdII vehicles.
exhaust on 95/96 may be a bit different. I had both years but with 351's. The OBD-II truck had two extra O2 Sensors so the exhaust may be slightly different to accommodate them.
