Seafoam or Power Service whos uses them and how
Just curious who uses which one and why? Is one better than the other? With the crappy fuel these day is it a good idea to run an additive in every tank full or add a little 2 stroke oil?
Last edited by powerstrokedieselfan; 01-28-2011 at 08:22 PM. Reason: added question
This would be worth a look
http://www.johnfjensen.com/Diesel_fu...itive_test.pdf
But to answer your question I run white bottle in the winter, just to try and help gelling. After reading the above link, ill no longer bother running the grey bottle in the summer
If you live in Spring, you can pretty much run the PS gray bottle year round. I keep a bottle of white on hand (or some Howe's) for those cold fronts that drop the temps down real cold at night for a few days, but otherwise just run the gray stuff. 74 here today so I'm not too worried about gelling fuel at the moment.
The 7.3 loves bio. Keep an eye on the weather this time of year and keep the tank full if you run it during a cold snap. I'd stay away from Sea Foam. Smells too much like alcohol to me and alcohol isn't good for the injectors.
No, I'm just North of Hillsboro. There are several NBS guys in the Houston area and a moderator for the Excursion section lives in Spring (at least it's a 7.3 Ex). I get down that way every once in a while. I think some of the Houston locals are planning another get together if you're interested. https://www.ford-trucks.com/forums/1...ton-texas.html
I run powerservice grey, trucks seems to run better and I do pick up milage. Any wear improvment is better then running with out. With the miles I have on my truck, what is worn is worn and my injectors are already getting tired so when I change my injectors I'l see about gettting something better. I find it harder to get the varieties that you guys get for wear improvers up in Canada. They can be found but are not available everywhere.
oh i met a guy who has an 08 cummins and he runs a full tank of b80 or b100 cant remember now every other tank and he says when he does the engine gets real quiet the whole tank plus he says sometimes while hes drive the truck will start to slow down he pulls over changes the fuel filter and its good to go again also he says his milage goes down during that tank he just funs it to keep it clean on the inside
Carmax
13
11-17-2015 08:42 AM
