FRx spring
Old Mar 29, 2011 | 12:05 PM
Kyle_KleinSS's Avatar
Kyle_KleinSS
FRx spring
Just got my frx in the mail yesterday. Will be putting it on possibly this weekend. What spring should I use? I was going to use the black one which is the highest pressure. I was thinking the more the better in this case. Am I wrong? Would using that one be the best?
Old Mar 29, 2011 | 12:18 PM
TexasRenegade's Avatar
TexasRenegade
I'm curious about that as well.
BUMP
Subscribed
Old Mar 29, 2011 | 12:29 PM
tdpower's Avatar
tdpower
Clay recommended using the gold one. Not sure exactly why but others can chime in on that. Have you already started the install? The plugs were a little bit of a pain to get loose. WD 40 and pb blaster over a few days made life a lot easier. Greg's tips in this thread helped out a lot. https://www.ford-trucks.com/forums/1...n-my-butt.html
Old Mar 29, 2011 | 12:31 PM
joeyd61's Avatar
joeyd61
55-60 psi silver spring
61-65 psi gold spring
66-72 psi black spring
Most here are using the gold spring..myself included....
Old Mar 29, 2011 | 12:36 PM
Kyle_KleinSS
Havent started yet I will spray then down with some kroil, and will probably go with the gold then
Old Mar 29, 2011 | 12:55 PM
PaysonPSD's Avatar
PaysonPSD
Whatever spring you use be certain it is not cocked when install is complete. A cocked spring pegged my 100 PSI fuel gauge.
Personally I would not alter the FPR without a fuel gauge and would also install an FPR rebuild kit.
Guzzle's FPR Rebuild Kit
Old Mar 29, 2011 | 01:29 PM
woodnthings's Avatar
woodnthings
I installed the factory spring in my GEN 2 FRx, I see 65-67 psi normally and 60-62 psi under WOT. My gauge sender is located post filter.
Robin makes a good point, you should always verify your mods before and after. You can pick up an inexpensive fuel pressure test gauge at most auto parts stores. I think even Harbor Freight sells them pretty cheap. That will allow you a baseline and a post mod reference to use.........besides it gives a reason to buy more tools!
Old Mar 29, 2011 | 01:32 PM
Kyle_KleinSS
Where do you put it at post filter? Mine is in the little plug in the back the test port I took out and its in there
Old Mar 29, 2011 | 01:37 PM
corey fletcher's Avatar
corey fletcher
I just put my FRx on this past weekend and used the GOLD spring. Truck runs fine. Those two square head plugs are pure H*** to get out! I also done the HPX, nice to kill two birds with one stone while things are apart...........
Old Mar 29, 2011 | 01:38 PM
woodnthings
There are two test ports in the fuel bowl. The one on the drivers side (easiest access) is pre-filter, the one at the bottom on the passenger side is post filter (pressure the heads see).
Old Mar 29, 2011 | 01:40 PM
Kyle_KleinSS
Ok mine is on the inlet one then, is the fitting for the outlet the same?
Old Mar 29, 2011 | 02:12 PM
joeyd61's Avatar
joeyd61
Yes it is, i just changed mine to post filter and used the plug on the pre filter side..
Old Mar 29, 2011 | 02:28 PM
Kyle_KleinSS
Thats what I have to do idk where that plug went to
Old Mar 29, 2011 | 03:13 PM
Ducci's Avatar
Ducci
Subscribed.
I will defiantly be watching this thread as I may try installing mine this weekend as well; if am not on the bike?
Old Mar 29, 2011 | 05:56 PM
woodnthings
Just use the plug you remove from the other port. Any #4 ORB plug or fitting will work, they are 7/16"-20 threads.
