Need template for 97 factory cab lights
Old 01-27-2011, 07:06 PM
59JEEPSTANG's Avatar
59JEEPSTANG
59JEEPSTANG is offline
Almost forgot, here we go: they are 1 5/8" back from the body line above windshield (not windshield moulding) of course middle one is centered, others are 12" on center from each other which leaves about 6" from the center of the outer ones to the outside edge of the gutter. When I bought a set from Ford in early 80's for my 76 the set actually came with a templete (long gone of course). Hope this helps.
Paul
Old 01-27-2011, 07:10 PM
Krisx125's Avatar
Krisx125
Krisx125 is offline
I put mine further back, when you look at the stock location they dont quite sit flat.
Old 01-28-2011, 04:07 PM
4CFarms's Avatar
4CFarms
4CFarms is offline
thanks guys i appreciate it 59jeepstang
Old 01-29-2011, 11:35 AM
Lanny Sutton's Avatar
Lanny Sutton
Lanny Sutton is offline
Originally Posted by 4CFarms
My truck didn't come stock with cab lights on the top and i wanted to put them in but i dont know the exact factory specs on their location. I just wanted to do it right so if anyone has the specs or website that tells me, i would greatly appreciate it. Also if u have any other tips on the installation and wiring that would help too.... Thanks
I'd like to trade roof skins with you.
Old 02-09-2014, 12:18 PM
Kouwenberg7.3's Avatar
Kouwenberg7.3
Kouwenberg7.3 is offline
is there a way to hook up the lights to your lights switch? Would someone be able to take a picture of this box you have to run the wires to behind the kick panel? Not sure if it's on my truck? Thanks
Old 02-09-2014, 12:25 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Holy dead thread.
They will PLUG into the plug at the passenger kick panel if you read this thread.
As for installing them..
https://www.ford-trucks.com/forums/1...ab-lights.html
Old 02-09-2014, 03:53 PM
Kouwenberg7.3
okay, thanks, my kit didn't come with the plug, just a switch to turn the lights on and off and a bunch of wire. I guess i will just have to go and get a plug then.
Old 02-09-2014, 06:32 PM
Diesel_Brad
Get a factory cab light harness and it will be a MUCH better setup than the aftermarkt junk you are dealing with now
Old 02-10-2014, 02:03 PM
4CFarms's Avatar
4CFarms
4CFarms is offline
IMO you don't even need a plug... I didn't have one with the kit I ordered. All you have to do is find out which wires are hot according to each setting of the headlight switch, i.e. when lights are off, marker lights on only, and both... Once you found the hot that runs to the correct setting you want the lights to flip on with then wire the lights into that hot wire. Lastly, make sure the ground is secure because if you don't then it WILL give you trouble
Old 07-09-2014, 04:12 PM
jle70's Avatar
jle70
jle70 is offline
Something I drew up. These are the most common measurements from searching many hours. The outside measurements will vary on truck model, of course.
3 in center
Lights Centered
Old 07-10-2014, 08:37 AM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Arrow
3 in center
Lights Centered
Reps sent.
blk450er
06-15-2017 05:22 PM
Thisguy65
05-29-2017 11:50 PM
Excursionator
1999 to 2016 Super Duty
05-16-2016 02:18 PM
78F-250Lariat
05-10-2016 08:57 AM
twisted84toyota
06-18-2009 09:31 PM
Quick Reply: Need template for 97 factory cab lights
