85 F250 2wd 460 - Can't get past 80kph
Would a stuck choke plate be a possible cause?...
I went out to the truck again for another look and the plate was a bit stuck as per the above photo...A little pressure and it now will flip shut and wide open...
I am planning on replacing the spark plugs and wires soon as well as the fuel filter.
Do a proper tune up, cap rotor, plugs, wires, fuel filters (the one in the carb inlet and the one on the truck frame rail), set the timing correctly and put some Seafoam in the fuel tank. Then see what problems, if any you still have.
Step down on the gas an the fuel already in the carb deals with it, once the float level drops then you would experience a running issue, not immediately. Whereas the ignition has to immediately deal with the richer fuel/air mixture. I get the feeling you are and EFI guy because that is what EFI does as there is no reserve fuel in a float bowl.
on
I'm 50 YOA and if his fuel pump is weak enough or his fuel filter is plugged enough that the thing is already running poorly just trying to get up to speed, then the float bowl is already almost empty. I've seen considerably more bad fuel pumps/fuel filters than I have bad coils. I don't want to argue with you about this, I just wanted to throw out another possible issue he *might* be having.
I am building a list of parts for the truck...
Recently added is a new ignition keylock... -31 degree weather and I turn the damn key and bent something...I think...
Also on my list is a new fuel pump for the front tank...When I switched tanks last night the truck ran for a bit then started to die out, switched to the back tank and it fired up again...
Course I will be doing items from cheapest to the more expensive...After all I can run on the back tank for a while...
Oh...For the record...I have had no running issues with the truck until I near the 80Kph mark...
Update...
I know it's been while since I've posted on here...Been lurking...
I've also kept the truck on the farm so it hasn't seen much for highway driving...
Took it to pick up some chickens...So was on the highway...Same problem after a few miles...
If I continuously flicked the switch between tanks I got her up past 80 without any more issues...Thoughts?
She has new plugs, wires, cap and rotor and coil...And filters have been changed...
But the sludge, rust, swarf... in the tank is still there.
Suction draws it to the in-tank filter (sock) until it restricts the flow to the point you can't maintain speeds above 50 mph.
Switching from one tank to the other allows road vibration and sloshing fuel to uncover the filter and you have better fuel flow.
(At least this is what I get from jas88's post)
on
Thanks for the update. $2 was the easy part. You forgot the labor charge for the troubleshooting and uninstalling, and installing the tank. Think of what you would have paid for a dealership to do that job. People wonder why they pay so much at the dealership these days.
Sent from my iPad using IB AutoGroup
dorkpunch
General Automotive Discussion
207
05-19-2016 07:59 AM
danny_1
1997 - 2003 F150
04-19-2000 08:22 AM
