Texas Chapter Join Chapter, Leader: LibTimothy
back tires grinding on f250
Old 01-14-2011, 08:17 PM
f-250muddin's Avatar
f-250muddin
f-250muddin is offline
hey, my f250 was sitting for a while i got her started up and i put it in 4wheel drive so i can take her out alil bit but when i was moving it the back tires were like grinding like they wanted to lock up does anyone know what can be causing that?? thanks
Old 01-16-2011, 04:15 PM
DRRXR's Avatar
DRRXR
DRRXR is offline
Sounds strange only does it on 4 w dr?
Old 01-16-2011, 04:40 PM
f-250muddin
well i dont know because the truck sits cus the transmission went out on it and in order to move it i have to put it in 4 high
Old 01-16-2011, 05:49 PM
93Fodge's Avatar
93Fodge
93Fodge is offline
Just for clarification, I've got to start off by asking: you already know that there is something seriously wrong with the truck, but you're going to drive it anyway by limping it around in 4wd?
Next question: The transmission went out, but you can drive it in 4Hi? 4wd doesn't create a top secret power transfer routing that allows you to harness the engine power direct to the front axle. The engine power still has to go through the transmission, and is then distributed through the transfer case to the front axle. I've had a clutch get burnt to the point where the only way I could drive the truck was in 4Lo & redline, and it would just barely drag itself around the shop. But I've never had a transmission "go out", and still be driveable in 4Hi.
Between your two posts though, I'm looking at these things: back wheels locking up & making a grinding sound and the truck only moves in 4Hi (assume 4Lo too)? I'd say it sounds a lot more like you've shelled out your rear axle than had the transmission "go out". Exploded the carrier, broke the cross pin, ran it without grease & seized a bearing or two, something like that. Pop your diff cover and start looking there.
Old 01-21-2011, 06:32 PM
itsnotanova's Avatar
itsnotanova
itsnotanova is offline
100% what he said^^^^^^
Old 01-21-2011, 08:01 PM
f-250muddin
well it didnt go out completely when like it still moves but you have to hit the peddel all the way to the ground for it to move alil bit but if i stick it in 4x4 it moves more if that makes better since
Old 01-21-2011, 08:34 PM
itsnotanova
Maybe something in the transfercase but the rearend is real easy to check first. Either pull the cover off the rear end and get a good look or maybe take the drive shaftoff and see if you still have problem. Another maybe would be your parking brake sticking or something goofy like that. hard to say without being there.
Old 01-22-2011, 06:47 PM
f-250muddin
alright ill look at that
Old 01-22-2011, 07:17 PM
Ak Ford Man's Avatar
Ak Ford Man
Ak Ford Man is offline
That sounds more like tha transfer case to me!!
Old 02-01-2011, 08:00 PM
93Fodge's Avatar
93Fodge
93Fodge is offline
Updates? Did you figure out what the problem was? I wanna know if my diagnosis was anywhere close to correct
Old 02-01-2011, 08:12 PM
f-250muddin
no sorry everyone i sold her lol ima gona miss her
Scyimon
11-04-2014 10:30 PM
JaredM91
12-03-2013 05:08 PM
mblanken881
09-24-2013 06:25 PM
Jayybird
1999 to 2016 Super Duty
07-05-2010 08:07 AM
Quick Reply: back tires grinding on f250
