99 F250 V10 Drive engages at random
So I'm having a rather odd problem with my truck. As I said, 99 Superduty V10 4x4 auto. I can physically shift fine, but it acts like drive, 2nd, or 1st don't engage. Reverse works every time, but when you go to drive it does nothing, acts like your still in neutral. I shift it through the gears but it won't engage. It doesn't do it all the time, just at really bad times(like parking lots, pulling out of driveways, etc. There is no ryme or reason to it. Sometimes you put it in park and back to drive and your gtg, other times you can cyle through the gears for 5min and go nowhere.
When it does engage, its after its rev'd a little high (about 15-1700rpms) but reving up catch it everytime. Today I drove it a few times with no issue, then it just wouldn't catch.
The overview:
-not everytime
-always goes into reverse, park and neutral
-good fluid level
-D, 2nd, 1st act the same, only engages sometimes
-no issues with P, R, or N
-acts fine once its actually in gear - acceleration normal
-little over 100,000 - don't know the last time trans filter was changed
I'm thinking some type of psi solenoid going out, and/or the filter and fluid needs changed. I don't know alot about auto's, but I know they work off psi changes. It just "feels" like a pressure issue. If it was mechanical or electrical I wouldn't expect it to be this intermittant.
Thank you very much for any info or ideas,
Brian
The overview:
-not everytime
-good fluid level
Brian
Is the OD-off light flashing?
Could be the switch on the side of the tranny that tells the PCM what gear you selected.
Could be lots of things. Some easy, some horrible. But definitely sounds electrical or pressure-related. If the OD light is flashing, get the codes read and go from there.
NCPirate
04-06-2015 11:35 AM
Brian460
05-10-2006 04:12 PM
