Engine Stand/Hoist
Haha... good timing on this one.
I just mounted my 5.8L on my engine stand last night... the problem of the cherry picker and the engine stand base interfering is a big one. What can be done is the engine stand can be attached to the engine with the engine on the floor/truck bed, then the stand lifted by the pivot area where the weight of the engine is normally carried, until its high enough to swing the stand upright.
I also had to remove the flywheel to mount it. I don't think I'd run it on the stand though, the gassers are one thing but i know when I start my IDI the whole truck rocks around, you wouldn't want your engine stand going through that.
That's even better, it would've been far easier had I not taken the engine and stand out of the truck onto the garage floor and done it that way instead!
It's good to think it out ahead of time... but that doesnt seem to happen all the time...
I didn't figure that out until I had the engine in the air and could neither get the engine stand inside the legs of my cherry picker nor lift the engine high enough.
I don't know if your area has a Harbor Freight or not, but you might look there. The stuff there is cheap (good and bad), so you would definitely want to err on the side of caution. If you watch, they will put thier stuff on sale and they always have a 20% off coupon you can use too. I recently had to work on a 351 and had it mounted on thier medium duty stand (1000lbs rated) with no issues. I think thier heavy duty stand is rated for 2000lbs. They have an online store too.
PapaBearYuma
24
11-12-2016 10:54 AM
n8ishooiam
Garage & Workshop
05-29-2011 06:59 AM
marty68
05-24-2006 01:02 PM
