Engine Stand/Hoist
Old Jan 4, 2011 | 07:54 AM
Scratcher's Avatar
Scratcher
Originally Posted by NorthernDiesel
Haha... good timing on this one.
I just mounted my 5.8L on my engine stand last night... the problem of the cherry picker and the engine stand base interfering is a big one. What can be done is the engine stand can be attached to the engine with the engine on the floor/truck bed, then the stand lifted by the pivot area where the weight of the engine is normally carried, until its high enough to swing the stand upright.
I also had to remove the flywheel to mount it. I don't think I'd run it on the stand though, the gassers are one thing but i know when I start my IDI the whole truck rocks around, you wouldn't want your engine stand going through that.
Good thinking................ I think what I will do then is bring the stand onto the tailgate and mount the engine to the stand whilst still suspended to the hoist, then simply lift both off the truck together. That way the legs of the hoist will be under the truck and I will be able to get it really close to the stand which will be on the tail gate. Funny how sometimes you miss the obvious.
Old Jan 4, 2011 | 08:11 AM
NorthernDiesel's Avatar
NorthernDiesel
That's even better, it would've been far easier had I not taken the engine and stand out of the truck onto the garage floor and done it that way instead!
It's good to think it out ahead of time... but that doesnt seem to happen all the time...
I didn't figure that out until I had the engine in the air and could neither get the engine stand inside the legs of my cherry picker nor lift the engine high enough.
Old Jan 6, 2011 | 07:48 PM
Tknomaj's Avatar
Tknomaj
Originally Posted by ricker1979
I don't know if your area has a Harbor Freight or not, but you might look there. The stuff there is cheap (good and bad), so you would definitely want to err on the side of caution. If you watch, they will put thier stuff on sale and they always have a 20% off coupon you can use too. I recently had to work on a 351 and had it mounted on thier medium duty stand (1000lbs rated) with no issues. I think thier heavy duty stand is rated for 2000lbs. They have an online store too.
I wish I had taken pictures of the heavy duty harbor freight engine stand. With a fully dressed 7.5 bolted to it and the head of the stand is bent and drooping is a UNDERSTATEMENT. If this was my engine I would buy a Quality stand OTC/LINCOLN
Old Jan 6, 2011 | 08:17 PM
Scratcher's Avatar
Scratcher
Those are way over my price range!
Old Jan 6, 2011 | 08:36 PM
charleswood6969's Avatar
charleswood6969
https://www.ford-trucks.com/forums/m...-dsc00016.html
Here's mine.
Old Jan 6, 2011 | 08:38 PM
Scratcher's Avatar
Scratcher
Originally Posted by charleswood6969
Here's mine.
Where's your's?
Old Jan 6, 2011 | 08:40 PM
charleswood6969
Old Jan 6, 2011 | 08:41 PM
charleswood6969
Computers do NOT like me.
I worked on this and the post above for you.
DaveS
Old Jan 6, 2011 | 08:46 PM
Scratcher's Avatar
Scratcher
Now that's a stand!!
Old Jan 7, 2011 | 10:29 PM
charleswood6969
Thank you, DaveS. I am computer illegitimate, er, I mean illiterate.
Old Mar 3, 2013 | 01:01 PM
turp's Avatar
turp
how about a 7.3 with heads removed? will a 1000 lb. rated stand hold safely?
PapaBearYuma
24
Nov 12, 2016 10:54 AM
Ossiemac
Jun 20, 2016 10:00 AM
n8ishooiam
Garage & Workshop
May 29, 2011 06:59 AM
vettman
18
Mar 23, 2011 06:31 PM
marty68
May 24, 2006 01:02 PM
