ICP/IPR Readings
ICP/IPR Readings
I'm slowly working my way through a no start issue on a 2003 F-350.
Using a Scangauge II I'm getting the following readings for ICP and IPR:
Initial Key on the IPR reads 14.4 %, as soon as I start cranking the engine over I get a steady reading of 77% the whole time I'm cranking. While cranking the ICP reading fluctuates between 150 psi and 350 psi occasionally bouncing over 500 briefly and then dropping back down to between 150 and 350.
If I understand correctly you need a minimum of 500 psi in order for the engine to start. I'm not sure what the correct IPR value should be and where I should start looking for my hpo problem.
IIRC from reading previous posts the 03 doesn't have the STC fittings but the hpop itself is a weak point.
Should my next step be an air pressure test, pull the IPR and inspect, or start shopping for an hpop. If I need to do the air test what is the easiest way to do this with the ICP in the back under the turbo?
Thanks for any advice
Yes, I checked voltages and had 47+ volts except for a brief reading of 42v during cranking that went right back up to 47+. I had forgotten to unhook the glowplug power for the test. I reflowed the solder as described in the tech folder and retested. Had 48v throughout the entire test but had glowplugs unhooked as I should have during the first test. At any rate I'm not positive the ficm is good because the voltage test isn't definitive, but I am pretty sure I do have a hpo problem due to the ICP reading.
I did try unplugging the ICP sensor, in fact through most of the troubleshooting and repair process ( I have found other issues that I have fixed along the way ) I left it unplugged. Still no fire. I'm not convinced I don't have other problems such as FICM, but I need to get the hpo up where it belongs before I continue elsewhere. Any input on what the correct IPR reading should be, and the best way to do the air pressure test on an 03? Thanks
piken
04-17-2016 06:23 PM
millwrightbrian
02-18-2015 03:27 AM
Racecarhauler
10-20-2009 01:41 AM
