1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
2003 Ford Expedition Wind Noise from passenger window after replacing regulator
Old 12-23-2010, 05:58 PM
TheMilkman00's Avatar
TheMilkman00
TheMilkman00 is offline
Ok, I am at my wits end with this. I replaced the window regulator on the passenger side of my truck TWICE (since while I was installing the first regulator, the notch that holds the door release lever broke ). Anyway, it is done, installed, and working GREAT.
The only problem is that there is a very small wind noise coming from that side that was never ever there. It sounds like the wind is coming through a very small hole. If I put my finger just over the A frame plastic on the door, it muffles the sound. I just don't understand where the sound is coming from since I really didn't do anything in that part of the door.
I have read that there are mirrors on some models that cause that. I taped up everything around the mirror and the sound was still there, plus I didn't do anything with the mirror. ANY IDEAS?!?!?!!
Old 12-24-2010, 06:30 PM
mudder1_2000's Avatar
mudder1_2000
mudder1_2000 is offline
Check to make sure your glass is sitting in the window track properly. I have a 99 navi and if I roll the window down and back up it likes to pop out of the track on the rear side of the door. Might be a similar issue with yours.
developer
2015 + Expedition & Navigator
22
09-18-2018 08:46 AM
RD16SDCC
1999 to 2016 Super Duty
10-24-2016 07:34 AM
TheStig80
2015 - 2020 F150
44
10-09-2016 03:01 PM
mssbass
2015 - 2020 F150
06-25-2016 07:53 AM
tolliewolly
6.7L Power Stroke Diesel
08-13-2014 04:27 PM
Quick Reply: 2003 Ford Expedition Wind Noise from passenger window after replacing regulator
