blown fuse ??
blown fuse ??
I was removing the inside light when the screw touched the bulb and sparked. After that my radio wont come on and the reading lights wont come on. also my windows wont let down. All other lights work correctly including the inside lights but not the manual reading lights. I've checked fuses and they all seem good. Any Help??? thanks
All of the items you mentioned are powered through the accessory delay circuit. This is a fused circuit (42) and controlled by the Accessory Delay Relay (#306). It is possible that what you did damaged that relay, even though the fuse should have protected it.
There should be a diagram on the side of that relay showing which 2 pins are the coil and which two are the contacts. If you take it out and put power and ground on the coil, you should be able to measure continuity across the contacts.
iwritesql
Electrical Systems/Wiring
05-13-2010 09:02 PM
MiKeYs 2k DiEsEl 4x4
08-01-2007 06:41 AM
