Modular V10 (6.8l)
very high idle V-10????
Old 12-14-2010, 03:34 PM
krice5's Avatar
krice5
krice5 is offline
99 F-250 with 6.8 started it today and it idled very high started around 1500 which semed pretty normal the started climbing to above 2000 to 2500 and then tried to kick it down went on up tp around 3000 and I shut it off started it a few times today same thing any suggestions possible throttle position sensor?? let me know if you can help thanks
Old 12-14-2010, 04:09 PM
jh818's Avatar
jh818
jh818 is offline
Are you sure you have a Ford and not a Toyota Prius?
Seriously, is the throttle body cleaned?
Old 12-14-2010, 04:21 PM
krice5's Avatar
krice5
krice5 is offline
Funny I am a Millwright At Fords Indy Plant wouldnt own a Toyota but yes it is clean and it is very cold here just started this morning it pretty much starts at around 1500 rpms and gradually climbs to upwards of approx. 3000 rpms
Old 12-14-2010, 05:13 PM
68 351 bronc's Avatar
68 351 bronc
68 351 bronc is offline
IAC controls the idle if your throttle body is closed tight.
Old 12-14-2010, 05:28 PM
jh818's Avatar
jh818
jh818 is offline
I don't know if the IAC valve could open that wide to make it run at 3k rpm. Wouldn't hurt to check it.
I was thinking that the butterfly in the throttle body was sticking when you tried to knock it down with the accelerator pedal.
Old 12-15-2010, 07:22 AM
rvpuller's Avatar
rvpuller
rvpuller is offline
A few years back I had idle problem and I found a little corrosion where the butterfly closes causing it to hang up. I cleaned it up and have never had a problem after that. Take off the air inlet tube at the throttle body and take a look and see if the butterflies are closing all the way.
Denny
Old 12-15-2010, 04:18 PM
lariat79sc's Avatar
lariat79sc
lariat79sc is offline
PCV valve caused my truck to idle up above normal.
KDAVID1
11-03-2014 10:43 AM
octaneforce
07-29-2011 04:13 PM
nosebreaker
1999 to 2016 Super Duty
03-29-2011 08:09 PM
Wells
12-18-2006 06:49 PM
FORDWRENCHHEAD
01-07-2003 02:52 PM
Quick Reply: very high idle V-10????
