High Idle
Old Dec 18, 2006 | 07:41 AM
Wells's Avatar
Wells
High Idle
My truck has a very high idle. I don't have a tach, but it seems to be around 1000 rpm. Is there a way to adjust the idle?
Old Dec 18, 2006 | 10:42 AM
spike552's Avatar
spike552
my trucks got a high idle too but only for a short period of time, i could be wrong here but iam sure its the ECT.
this is from the chilton manual
When the engine coolant is cold, the ECT sensor signal causes the pcm to provide enrichment to the air fuel ratio for a good cold drive away as engine coolant warms up.
Old Dec 18, 2006 | 11:29 AM
kell104's Avatar
kell104
Mine idles up to about 1000 too when it is really cold, but only for 30 seconds or so.
Old Dec 18, 2006 | 03:57 PM
Wells's Avatar
Wells
Mine idles up when it is cold, but then lowers to a constant 1000 rpm. I have read some articles about idling high when it is cold, but this seems a bit too high. After it warms up a bit the idle lowers, but only to about 1000 rpm (guessing).
Old Dec 18, 2006 | 06:45 PM
lmooreF250's Avatar
lmooreF250
Check for a vacuum leak. That will usually raise the idle.
Old Dec 18, 2006 | 06:49 PM
00bucker's Avatar
00bucker
Check out your IAC. Idle Air Control Valve
Gerryatrics
1997 - 2003 F150
19
Mar 30, 2014 06:11 PM
Midnight Ride
6.7L Power Stroke Diesel
Jun 15, 2013 06:05 AM
Krisx125
Dec 8, 2009 11:49 AM
madman666
Dec 11, 2001 09:06 PM
jopey
Oct 11, 2000 01:50 PM
