High Idle Shake
Old Nov 2, 2014 | 04:48 PM
KDAVID1's Avatar
KDAVID1
High Idle Shake
I noticed today when I flipped the high idle on there is a VERY noticeable shake in the truck? What could possibly cause this?
Old Nov 2, 2014 | 05:05 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Bad fuel, bad fuel filters, failing fuel pump, HPO leak, failing HPO pump, FICM problems, a fuel injector (or two), base engine issues like a valve, lifter, or rings, charging system or battery issues...um,,I'm probably missing a bunch of stuff.
Do you have an OBDII monitor of some sort? Sounds like it's missing, fuel pressure test and fresh filters are a good starting point.
Old Nov 2, 2014 | 05:18 PM
KDAVID1's Avatar
KDAVID1
I was thinking as much--trying to eliminate what I can quick.
I have sgII and torque pro both. Was just looking for icpv set up for torque pro (if it has it) Fuel filters have about 8K on them batts and alt are putting out good not getting any codes.
No smoke of any kind--still need to get to the shop to get a contribution test--trying to do all I can at the house beofre I go that route.
Old Nov 2, 2014 | 05:26 PM
tonefordays's Avatar
tonefordays
My truck is having similar issues, however it only shows up when the engine is cold. I had a contribution test done on it a couple days ago, and I had the #8 injector showing up a little weak. Once the engine gets up to temp, the shakes go away.
However, I guess I won't know for certain if the injector is the issue until I get it replaced.....
Old Nov 2, 2014 | 05:49 PM
KDAVID1's Avatar
KDAVID1
question--if it is an injector going bad would a rebuild fix it or is that just a stiction fix?
Old Nov 2, 2014 | 06:57 PM
Rusty Axlerod
If by rebuild you mean the spool valve polishing procedure in the tech folder -that's pretty much for stiction issues. Does it do it fully up to temp?
Old Nov 2, 2014 | 07:14 PM
KDAVID1's Avatar
KDAVID1
Thought that was the case. It did last week but not as bad as today. I hadn't started it until today since Thursday. It's definitely not stiction and what I notice most of all are the rpm changes ( not huge but noticeable) and the shake when high idle on ( same rpm swing)
2006 F350 4X4
Old Nov 3, 2014 | 10:43 AM
KDAVID1's Avatar
KDAVID1
Mind of it's own--didn't do anything unusual today?
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
32
Dec 15, 2019 05:57 AM
cbizzme
May 5, 2018 01:47 AM
Rigormortise
60
Apr 30, 2013 06:30 AM
2006powerstroke90
Mar 29, 2012 07:15 AM
beachbummin220
Mar 5, 2007 07:02 PM
