i have 2004 e350 6.0 Turn key on lights and gagues come on. it doesn't turning over. checked both batteries, good 820 cca each, starter tested good, checked all fueses and relays??? please help what do i check next
Were you messing with a tuner before you had the problems? The reason I ask is because I wiped my PCM clean one time and the dash would light up but no cranky.
The most noticable thing was it gave me dashes on the odometer and not milage.
Dunno then I know that when the PCM is wiped or bad it will do exactly what you are saying with the dashes and all, but check out the no start check list in the tech folder.
If you have a way to haul it to the dealership, you could have them attempt to reflash the truck. If they are able to flash it and it starts up then the PCM may have been wiped. It would probably cost $60-$100 to reflash.
If the PCM is bad or it's a totally different problem it probably wont help, but they would be able to tell you if it is a bad PCM.
