1978 - 1996 Big Bronco
IGNITION KEY SWITCH TEST ?
Old Jan 14, 2011 | 06:17 AM
jmoe's Avatar
jmoe
Question IGNITION KEY SWITCH TEST ?
Anybody know the easiest way to test to see if it's the key switch on an 84 Big Bronco? There is nothing when turning the key, battery's good, the solenoid and starter are suspect, but before buying parts I'd like to check the switch.
Old Jan 15, 2011 | 01:04 AM
greystreak92's Avatar
greystreak92
With the key held in the "START" position, you should have battery voltage at the RED/LT. BLUE wire on the solenoid on the passenger inner fender. If not, check the neutral safety switch or the clutch safety switch (depending upon transmission in the truck).
Old Jan 15, 2011 | 03:21 AM
jmoe's Avatar
jmoe
Sounds easy enough, thanks for the help !
Gresan
Oct 7, 2016 10:32 AM
sawmaned
WTB - Parts & other
Aug 1, 2015 03:44 AM
glw165
Modular V8 (4.6L, 5.4L)
Dec 14, 2014 05:03 PM
ItsAFord55
Mar 24, 2011 03:24 AM
averee1010
Nov 18, 2010 10:18 PM
