C6 tranny does not move after engine install
Old 03-02-2003, 06:57 PM
skyrader's Avatar
skyrader
skyrader is offline
Question C6 tranny does not move after engine install
just finished pulling, resealing, reinstalling 400 cu. in. engine mated to a c6 tranny in 1980 F-350 4x4. Engine is fine and NO Oil leaks as prior but now I have no tranny, it won't move forward or reverse ! I pulled engine with torque convertor attached and obviously loosing some tranny fluid in the process. reinstalled engine same way with torque conv. attached. everything lined up and in fact it was an easy install. I added 2 qts. tranny fluid via filler tube prior to starting. Fluid level has not gone down as I thought it would and no forward or reverse gears as mentioned above. My question is what did I do wrong ? if anything, and what could be the problem ? is the tranny pump not engaged for some reason to pump fluid into the convertor ? and if so how can I correct this without pulling the engine again or the tranny ?
Any ideas would be greatly appreciated.
Old 03-03-2003, 08:47 AM
big1's Avatar
big1
big1 is offline
NEVER EVER INSTALL ENGINE WITH CONVERTOR ATTACHED.
Alway's install convertor to transmission first, then install the engine to the transmission.
You have probably torn the pump "Dog ear's" completely off.
Pull the transmission with convertor back out. I believe you'll find I'm right.
Old 03-03-2003, 02:56 PM
big1's Avatar
big1
big1 is offline
I tried to edit this post just after I posted it. C6 pump's don't have "Dog ear's" however you still more than likely damaged the pump upon installation.
corytcline
06-25-2013 10:50 PM
johns95
06-21-2013 03:52 PM
bentcipher
1999 to 2016 Super Duty
25
10-23-2010 10:29 PM
278broncos
03-26-2010 11:33 AM
Quick Reply: C6 tranny does not move after engine install
