Montana Chapter Join Chapter , Leader: Sailor_Roy
smoke switch???
Old 12-22-2010, 01:43 AM
PstrokeN's Avatar
PstrokeN
PstrokeN is offline
smoke switch???
have any of you diesel boys ever done a smoke switch? i hear you take the green wire from the map sensor and splice a switch into it??
Old 12-23-2010, 12:23 AM
sledheadm7's Avatar
sledheadm7
sledheadm7 is offline
what truck is this for
Old 12-23-2010, 12:55 AM
PstrokeN's Avatar
PstrokeN
PstrokeN is offline
smoke switch
my 99 psd i heard its the green wire off the map sensor but wasnt sure
Old 12-23-2010, 08:38 PM
DasCheckers's Avatar
DasCheckers
DasCheckers is offline
From what I know you have to have a tuner, and then buy a smoke switch for it. It increases fuel and decreases boost.
Old 12-23-2010, 10:34 PM
PstrokeN's Avatar
PstrokeN
PstrokeN is offline
switch
stoney its me joey i have a chip juice with atittude
Old 12-23-2010, 11:38 PM
DasCheckers
Hey man I thought that might be yo bish ***.
Do you have 3 wires running to your map?
Old 12-23-2010, 11:58 PM
PstrokeN's Avatar
PstrokeN
PstrokeN is offline
yeah three wires i heard u can slicew into te green one and i seen a guy do it on a 01 cummins with three wires off the edge chipp and he sliced the pink and black wire to a switch i have 2 blks and one green i sliced the green and powered blk to a swich i hit the check engine light comes on and it smokes a little more nothing crazy tho? these guys were talkin rollin coal lik a mother, then i hit the switch off and after a little cel goes away, but with it chipped it barely smokes on setting 5 and the low boost on 5
Old 12-24-2010, 11:00 AM
DasCheckers
From The Cummins Forum,
Originally Posted by Mopar1973Man
"A - 5V+
B- Signal
C - GND
This 3 wires can be in in order from year to year. Especially if you replaced a MAP and got the adapter.
But you want to shutdown the signal lead going to the Edge Comp not the MAP lead to the ECM!
But MORE SMOKE mean LESS MPG. Unburnt fuel... "
Also a quote from Gale Banks @ Banks Racing,
Originally Posted by Gale Banks
"Smoke is the negative legacy of diesel - it's just plain wrong. It's power you can see but not use" ~Gale Banks
Old 12-24-2010, 11:31 AM
PstrokeN's Avatar
PstrokeN
PstrokeN is offline
ok i tink did it right then i put th 5v and singnal to a switch
Old 12-24-2010, 03:11 PM
DasCheckers
I've read a couple different things man, I think you did it right though. Have you tried unplugging the map completely? Just to test, not to leave off permanently haha.
Old 12-24-2010, 05:51 PM
PstrokeN's Avatar
PstrokeN
PstrokeN is offline
switch
no i havnt unplugged it i will try that tonight and see what it does b/c i get more smoke then i did with out the switch but its not alooooot, and i thought i can throw her in 6th gear and lug her to get alot but no it doesnt smoke till thje turbo spools a little then at high rpm it wont smoke idk lol ill try unplugging it
Old 12-24-2010, 07:08 PM
PstrokeN's Avatar
PstrokeN
PstrokeN is offline
i unplugged it and it smokes but it doest have the CEL like if i it the switch?
Old 12-24-2010, 08:27 PM
DasCheckers
Permanently unplugging the MAP isn't advised, but you might have the wires hooked up to the switch wrong or something.
The switch should dictate that there is no boost, therefore dumping excess fuel to the engine, creating more smoke!
Old 12-24-2010, 10:44 PM
PstrokeN's Avatar
PstrokeN
PstrokeN is offline
well theres a tanish wire too wonder what that does?
mountain dewd
06-03-2016 04:31 PM
alexisvfd
11-19-2015 10:55 PM
yewdall
18
04-02-2013 04:04 PM
slim613
21
01-14-2011 01:07 AM
CarolinaMafia
15
01-19-2009 09:49 AM
Quick Reply: smoke switch???
