smoke switch
Old Jan 11, 2011 | 01:41 AM
slim613's Avatar
slim613
smoke switch
so wats this thing iv been hereing about a smoke switch that make the computer think the turbo is turning at full speed but is actualy not???
is it a good idea jw
Old Jan 11, 2011 | 03:32 AM
Robbgt's Avatar
Robbgt
That's for 6.0 PSD's. VGT smoke switch. Could always use the "walmart bag mod" if you want some smoke.
Old Jan 11, 2011 | 05:40 AM
evans213's Avatar
evans213
"Wal mart bag mod" now I've got to hear how to do this. Sounds a little risky on damaging the motor
Old Jan 11, 2011 | 06:12 AM
Robbgt's Avatar
Robbgt
It's patent pending by Tim (TJBeggs)
Discussed...
https://www.ford-trucks.com/forums/7...et-is-out.html
https://www.ford-trucks.com/forums/8...ml#post7871450
https://www.ford-trucks.com/forums/8...ml#post6964560
https://www.ford-trucks.com/forums/7...ml#post5875479
Please... don't actually put a bag of any sort over your intake and run your truck..
Old Jan 11, 2011 | 08:18 AM
evans213's Avatar
evans213
So no one has thought of a smoke switch for the 7.3?
Old Jan 11, 2011 | 08:20 AM
Robbgt's Avatar
Robbgt
I think the "smoke switch" on the 6.0's does something with the VGT, I believe it leaves the vanes open so the turbo doesn't light as much with rpm=less intake air with more fueling=smoke... we don't have VGT's on the 7.3
the "smoke switch" for our trucks would be a hot chip on a truck with some built sticks.
Otherwise, even on the "smoke" setting I had on my chip, the stock 90cc's just don't dump much fuel to smoke, even power-braking it.
Old Jan 11, 2011 | 09:27 AM
superduty4x4's Avatar
superduty4x4
Plenty of people have thought of it, but there is no way to make a smoke switch for a 7.3. If you want smoke, do the tjbeggs patent pending mod already mentioned or nut up for a good custom tuned chip (at a minimum) so you can make smoke. Just use your smoke wisely, diesel owners have a bad enough rap as is.
Old Jan 12, 2011 | 02:18 AM
slim613's Avatar
slim613
alright thanks yall
so whats the best performance chip for this motor for black smoke and performance i go on youtube and see SMOKE so how r they doing it?
i hate the plastic bag idea ya screw that idea
Old Jan 12, 2011 | 06:31 AM
fishmanndotcom's Avatar
fishmanndotcom
you could always dump 10 gallons of used motor oil in your fuel tank. that'll smoke everything up! or get a fog machine and mount it under your truck
why does it matter if your truck smokes or not? sounds silly to me to go around smoking everything up.
-cutts-
Old Jan 12, 2011 | 07:02 AM
Robbgt's Avatar
Robbgt
-cutts-
^^what Cutts and Chase said. Diesel owners already have a bad enough rap sheet as it is.
As I had mentioned above, the stock injectors just don't dump enough fuel for much smoke, even with a hot chip. Those 'videos' your talking about more than likely have some modified Injectors.
Old Jan 12, 2011 | 09:19 AM
superduty4x4
Smoke is not performance, smoke is just wasted fuel. Yeah, it can be fun once in a while to select a hot tune and roll some coal, but don't go blacking out intersections at every stop light just to be an ***.
Old Jan 12, 2011 | 12:33 PM
Zack88's Avatar
Zack88
You could make a very good running truck for the money you are wanting to waste by pouring unburned diesel fuel out of the exhaust for no reason. People that do that are just being an *** and are the reason why we are having to deal with more emissions bs all the time. Get an intake, exhaust, good chip and then you can make a little bit of smoke when pulling like the truck is meant to. God I have another reason to never get a 6.0 now if they actually make smoke switches for them.
Old Jan 12, 2011 | 02:23 PM
slim613's Avatar
slim613
i dont wanna be black smoking all the time like in every intersection just wen i mash on it hard wen ppl r riding my ***
Old Jan 12, 2011 | 07:53 PM
1982_f150's Avatar
1982_f150
hahah hell yea brother,
Old Jan 12, 2011 | 08:05 PM
YoungFordAddict66's Avatar
YoungFordAddict66
I hear that. And the only thing that i have seen or heard of other than putting a bag on the intake is PHP 6 pos chip that has a tune called the "smoke show" tune. Yea its on my list of tunes when i get the chip.
