How do I calibrate my gauges?
Old 11-11-2010, 03:08 PM
mojo79's Avatar
mojo79
mojo79 is offline
I just pulled my instrument panel out to troubleshoot an oil pressure gauge problem. Now my gas gauge appears to not be acting right.
How do I calibrate these gauges?
Second question: The oil gauge issue...
I set the gauge arm to Low as a starting point. When I gave power to ignition, the gauge arm moves backwards way past the LOW pressure mark. What is this telling me?
Thanks!!
Old 11-11-2010, 04:35 PM
Duct Tape Racing's Avatar
Duct Tape Racing
Duct Tape Racing is offline
I heard that disconnecting the battery or instrument cluster with less than 1/4 will cause It to lose the memory. Try filling the tank, disconnecting the batter for about a few minutes then reconnect it.
Old 11-11-2010, 08:13 PM
Eddiec1564's Avatar
Eddiec1564
Eddiec1564 is offline
Check the printed ckt traces on the cluster. Probly one or more are bad when you had the cluster out. Problem sounds like a grounding issue. Also the IVR(insterment voltage regulator) could be going bad. Usually the other gauges will show the same problem if thats bad. Last but not least is the oil sending unit is bad. Those things usually fill up with oil and cause wierd readings before they start leaking oil out.
There is no real way to "calibrate" these gauges as they are not accuret to begin with.
Old 11-11-2010, 08:20 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,683 Likes on 1,359 Posts
Put it all back together. Go out and find the oil pressure sending unit. It's location will vary depending on what engine you have. If you have a 302 or 351w, it will be down near the oil filter and fuel pump.
Pull the wire off the sending unit. With the key in run, engine off, put the sending unit wire on to a good ground. The oil pressure gauge should swing full scale either high or low. Then take the wire off ground and let it hang in the air, touching nothing. The gauge should swing full scale the opposite direction. If it passes this test, then the wire and the gauge are good, and there is a problem with the sending unit.
This test will work for all the gauges. For the gas gauge, simply pull the wires off the tank, ground and un-ground the wire and the fuel gauge will swing back and forth if all is good with the gauge and the wire to the gauge. Same for the temp gauge also. It has a sending unit on the engine like the oil pressure gauge.
Old 11-11-2010, 09:01 PM
mojo79's Avatar
mojo79
mojo79 is offline
Well, I replaced the sending unit this evening but that did not fix issue. All the other gauges seem to be fine.
Where is the IVR located? This is a 1995 F-150.
I'll double check the cicuit traces tomorrow, I looked at them earlier today to make sure the gauge connections were seated on them, did not see anything unusual.
Running out of ideas... I suppose it could be the dang gauge itself.
Old 11-12-2010, 02:21 PM
Eddiec1564's Avatar
Eddiec1564
Ah a 1995 truck, the oil gauge is not a actual gauge, its more like a idiot light. After 88 Ford made all oil gauges either show "normal" or low depending if the oil pressure is over 7 psi. There is a mod to make it work like a proper gauge, but you'll need to look in the 87 to 95 Forums, I have posted there about it.
Old 11-12-2010, 05:04 PM
Franklin2's Avatar
Franklin2
You are not going to find a IVR on a 95 truck. But my tests are still valid for that year also. And the other poster is correct, your oil pressure guage is not really reading oil pressure like you think. It's either in the middle or it's on zero, no inbetween, it doesn't really really read the pressure on the later trucks.
Old 11-15-2010, 01:52 PM
mojo79's Avatar
mojo79
mojo79 is offline
yep, i understand it being an idiot light. My problem is that it reads way past the Low mark, I can manually move the hand to center gauge, and when I give power to ignition, the hand moves way left. When I take the cable off the switch, it does not move, when I ground it, it does not move. I put my Fluke meter on the wires and the wires have continuity, no open wires. I suspect something is grounding the signal wire some where.
I installed an after market gauge yesterday just to be sure I actually had pressure and all is good at 53psi.
Old 11-15-2010, 06:48 PM
parr4's Avatar
parr4
parr4 is offline
"I installed an after market gauge yesterday just to be sure I actually had pressure and all is good at 53psi"
Smart move! Might consider a Coolant Temp gauge as well. Real mechanical gauges are the way to go....IMO
Old 11-15-2010, 07:16 PM
mojo79's Avatar
mojo79
mojo79 is offline
Yep, I installed a dual set with oil and water gauges... took some work, but all working good. I would just like to see the original gauge work as well. I took the time to put in "T" connections so that both original and aftermarket would work together.
jr105
2015 - 2020 F150
54
10-13-2016 09:27 PM
elkarcher1716
11-24-2015 09:38 PM
CharlesNeff
07-17-2007 06:51 AM
hedgeapple
Electrical Systems/Wiring
08-26-2004 11:46 PM
baddestbronco123
1978 - 1996 Big Bronco
04-23-2002 10:22 PM
Quick Reply: How do I calibrate my gauges?
