Leaf Spring question
Search out the many threads here about the "B Code" spring swap and "Modded" B's. If your set of freebies has the extra overload leaf on the top of the spring pack you will need to remove it or it will damage the rear A/C lines. I recently was also given a set of rear B's and front X's, as soon as I can get some time off I will be doing the full swap with the modded rears. The only thing I need to get still is the 3.5" rear blocks (needed to level out the rear after the much heavier and taller X's are on the front).
Everything you ever wanted to know about the Excursion spring swap mod can be found here.
https://www.ford-trucks.com/forums/789595-attn-dup-steering-wander-search-results-for-you.html
It depends on what code springs you have. If you have B code springs, then yes.
Stewart
Which springs are going on the front?
If I take off the overload spring it should be a exect swap?
Stewart
aguitarestv
11-06-2014 07:12 PM
adamzelazowski
02-24-2009 12:40 PM
Blue89F150
01-19-2004 09:42 PM
