73 F250 crankcase vent system question
Hello. My recently purchased 73 Ford F250 w/ a 390 motor is in need of some new valve covers. I currently have the stock set up covers with a PCV valve one side and a oil filler cap with a vent hose connected to the air cleaner. My current air cleaner is an after market and will be replaced with an Edelbrock Signature series round style.
I bought some Edelbrock signature series valve covers. Each cover has a grommet hole. I will use one for the PCV valve that hooks up to the carb and the other for the oil filler cap. Can I leave the PCV valve hooked up and replace the oil filler cap hose assembly with a breather cap? If that will not work what type of cap can I use that will work with a grommet plug?
Thanks for the help.
Could I use this? <a href="http://paceperformance.com/i-5005962-signature-series-valve-cover-breather-edelbrock-4403.html">SIGNATURE SERIES VALVE COVER BREATHER EDELBROCK 4403</a>
Or should I use this? <a href="http://www.summitracing.com/parts/KNN-62-1516/">K&N Crankcase Vent Filters</a>
Thanks.
Thanks.
Tomget
05-24-2015 09:21 PM
johnson2007
08-21-2011 11:39 PM
hooler1
04-16-2011 11:00 PM
dgpruitt
03-25-2005 05:14 AM
