Installing O rings (HPOP & fuel dump)
I just bought the mechanics kit from Diesel O-rings.com and I'm about to work on my 99 F250 CC. I downloaded the instructions from the site and I have the Chilton's manual but this is my first diesel project. I know it leaks diesel and I think a little oil. Reading threads from this forum lead me to start at the HPOP and fuel dump valve. Any pointers or things I should know before starting this project. Thanks for the help I've already gotten.
Jason, MI
Jason, MI
If you're going to try to combat all leaks, go for the pedistal o-rings under the turbo and pedistal and another potential leak is the EBPV, many gut it it can also be rebuilt if leaks are there as well. Inspect the fuel lines, and returns running along the heads, the have been known to wear around the vibration clamps causing a huge fuel leak, If wear is noted I would atleast remove the clamps and rewrap them before installing to prevent failure.
GUZZLE
This "kat" made me believe, that i'm a diesel mechanic now...LOL
Has everything you need, perfect write up/walk through, for all "basic" mods and maitenence for your ride....
Welcome to guzzle's Ford PSD Maintenance Web Page
Studawg
12-22-2015 09:05 AM
Studawg
South Carolina Chapter
12-21-2015 09:42 AM
stevestroke01
01-05-2015 07:15 AM
Punisher29073
01-28-2014 05:27 PM
