Go Stancor! My Napa GPR 109 cost more then it and it was made like junk! I broke my new one during installation because you cant put any torque on the posts! NONE, ZERO. The same post broke off as i found the one did when I was removing my old one. Then you gotta mount it 90* off so ur yanking on wires and such.
Id go with Stancor. I am if i ever need one again. No questions asked.
Stancor is the ONLY way to go. I hear too many problems with the Napa GPRs etc. I have had two OEM GPRs and now i have the Stancor when my last one went. No issues. THis GPR is solid as someone said above
I used the Napa St36 & have had no issues yet in a year. It was mid winter & I needed one quick & couldn't find a Stancor local so I did some research & found the ST36 is equivalent in specs to the Stancor.It pretty much bolts up the same as the OEM too. Store Locator | NAPA Online
If it doesn't hold out I'll try the Stancor next time.
