Hesitation
Old Jul 1, 2010 | 02:13 PM
jgilrfr's Avatar
jgilrfr
Hesitation
I am having a problem with hesitation.It happens when I am at idle and tap the gas,idling up no hesitation but when it comes down it cgugs and you can see the tach needle drop and then come back to the idle position,and it happens in rvers when I tap the pedal to to start backing up.I have no diagnostic equipment and average mechanical ability.I am supposed to be leaving for syracuse,ny area today and dont know if its wise to make the trip with it doing this.Any thoughts or advice is greatly appreciated. John.
Old Jul 1, 2010 | 02:41 PM
riverrat41's Avatar
riverrat41
Welcome to FTE John
This sounds like it could be the Cam Position Sensor if you have not changed it in a while.They will cause these symptoms.Does it ever die on its own or just has the hesitation?
Old Jul 1, 2010 | 03:02 PM
Duck Hunter81's Avatar
Duck Hunter81
I 2nd what Barry said. Might want to check fuel filter also.
Old Jul 1, 2010 | 03:22 PM
jgilrfr's Avatar
jgilrfr
I had cps changed through the recall not long ago maybe 2 years,I changed the fuel filter,cleaned my 6637 filter also
jgilrfr's Avatar
jgilrfr
It doesnt die it just hesitates,thanks for responding
Old Oct 16, 2010 | 02:07 AM
jgilrfr's Avatar
jgilrfr
IPR ends up being the culprit!
