Ford F-250: Water Pump Reviews
Browse this review of the most popular water pump brands for the F-250 or F-350 Super Duty.
This article applies to the Ford F-250 and F-350 Super Duty (2005-2014).
Water pumps are one of those parts that you don't give much thought to until you need a new one. They play an important role in keeping your engine cool and running right. Just like most parts, when the time comes to replace a water pump, you have a lot of different options. You could just go with a stock pump, but perhaps you want something with more output, or maybe you are looking to add some performance to you truck. Keep reading for a brand comparison which will help you choose the right water pump for your specific needs. The four water pumps covered here are very reliable and are all direct fit to the Ford F-250 or F-350 Super Duty. The differences come down to varying prices and warranties.
Water Pumps
AC Delco |
Bosch |
Gates |
Airtex | |
Price |
$45 | $59 | $41 | $50 |
Weight |
4.2 lbs |
4 lbs |
4.6 lbs |
4 lbs |
Dimensions |
5 x 5 x 5 | 9.5 x 6 x 5.3 | 6.5 x 6.5 x 6.4 | 11.8 x 7.6 x 6 |
Part Number |
GMB 125-6050 | 97181 | 43504 | AW4130 |
Warranty |
Lifetime | 1 year | 1 year | Lifetime |
Best Value: Gates
AC Delco
Price - $45
Weight - 4.2 lbs
Part Number - GMB 125-6050
Dimensions - 5 x 5 x 5
Warranty - Lifetime
AC Delco makes a solid OE replacement water pump that won't break the bank. They are a popular option for those very reasons, and if you are running a stock engine their performance will be more than adequate. With a lifetime warranty, you can be confident that when you install one you won't have to worry about it. Recommended if you are looking for a good performance water pump without spending too much money.
Bosch
Price - $59
Weight - 4 lbs
Part Number - 97181
Dimensions - 9.5 x 6 x 5.3
Warranty - 1 year
Bosch pumps are made with 100% OE parts, making them a great direct replacement that is as close to stock as possible. They exhibit great quality and value and are a notch up the ladder from AC Delco. However, they do not have as good of a warranty as AC Delco pumps. But then again, if they last, you won't need to use it. Recommended if you are looking for a stock replacement.
Gates
Price - $41
Weight - 4.6 lbs
Part Number - 43504
Dimensions - 6.5 x 6.5 x 6.4
Warranty - 1 year
Gates makes an excellent product for little money. Their water pumps are known to be durable and undergo extensive testing of seals and bearings, along with leak tests, before being shipped out. Gates pumps are also made with a cast aluminum housing and stamped steel impeller. Gates may not have the brand name recognition of Bosch or AC Delco, but they make a good product at a good price. Recommended if you are looking for a good value water pump.
Airtex
Price - $50
Weight - 4 lbs
Part Number - AW4130
Dimensions - 11.8 x 7.6 x 6
Warranty - Lifetime
Airtex makes a great quality product for the price. Their pumps feature durable housings that are precision machined for a great fit and proper sealing. They are built to OE specs and tested before they leave the factory to ensure proper functionality. Airtex water pumps have a great reputation among community experts and are well worth the extra few dollars that they cost compared to a standard pump. Recommended if you are looking for a good pump with a great warranty.
Related Discussion and Site
- Water Pump Options - Ford-Trucks.com
- Water Pumps - TheDieselStop.com
