Sponsored by: Real Truck
Should I use C-4?
Old Jun 18, 2026 | 06:46 PM
8 lug nut's Avatar
8 lug nut
5th Gear
Should I use C-4?
I have 2002 F-250 5.4 Triton I am working on and am in the process of removing the heads. On Monday, trying to remove the harmonic balancer I was using a Snap On puller and it BROKE. The tool truck dude texted me back he had to order one.
I went to China Freight and picked up theirs and it is bending, I am using heat only around the center of the damper around the snout and Kroil penetrating oil. Combination of heat/oil/puller with big battery impact.
Bolt wasn't a problem but the power steering pully was tough also. I am probably at 10 times, it has moved a 1/4" maybe?
Any suggestions? I need help!
Old Today | 05:06 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
That's extremely odd....
Soak it with some PB Blaster for a couple hours then heat it up and try again. It shouldn't fight you THIS much.
My only thought is that if someone put loctite 262 or 263 on there, that would explain why it won't come off. Either that or if it's just that rusty where you live
Old Today | 07:01 PM
8 lug nut's Avatar
8 lug nut
5th Gear
I feel like a complete moron, there was another washer and I didn't have small enough center to go through the washer and it was stuck in the recess of the balancer in front of the crank. Heat and tapping around it with a brass hammer and Kroil loosened it up to where I could see it. No video I watched showed that washer or spacer and I do NOT have a manual for this engine.
I got that out of the way and it came off. I broke the Snap On puller out of stupidity.
thanks for replying!
Old Today | 08:06 PM
Pikachu's Avatar
Pikachu
Don't worry. We've all made mistakes like that. I used to make mistakes all the time, but I haven't bought anything from SnapOn in ages : )
Old Today | 08:15 PM
Toreador_Diesel
I legit thought that washer was in the way but figured it came out with the nut, but all good now! It happens to the best of us lol!
Yeti1978
Jul 21, 2016 10:19 AM
KoolAidMan888
Jun 4, 2012 09:25 AM
kameronth
1978 - 1996 Big Bronco
Jul 10, 2004 10:13 PM
ronca2
1983 - 2012 Ranger & B-Series
Mar 3, 2004 10:11 PM
BlueBoy
Jul 1, 2001 07:15 AM
