Steering Column/Wheel Clicking/Rattling
Old Jun 8, 2026 | 11:41 PM
reecedowler's Avatar
reecedowler
4wd High
Hello all, i have a 2017 f250 lariat with a clicking noise coming from steering wheel, its been present for a few months, started when on round-a-bouts or turns to sound like a marble rolling, on bumps or gravel roads the clicking is constant, I was able to duplicate in a video, I removed the air bag, clock spring, and other trim around the steering wheel. I have been unsuccessful finding the source. I sprayed WD40 on all UJoints/Bearings to see if that was it, still present. I am lost at this point, has anyone else had this issue? any ideas on what this may be? Note that this only happens in motion, When going under 5 mph it wont make the noise, not even when jacked off the ground with suspension unloaded or loaded. Clicking noise sounds like it comes from right in steering wheel above 5 mph. cant feel the rattle or stop on any wires or modules.I have tried different telescoping and tilt positions but it doesnt change anything. Any help appreciated. Video attatched below
File Type: mov
Old Jun 9, 2026 | 10:46 AM
GoinBoarding's Avatar
GoinBoarding
Not sure if it's the same but I had a click in my column. Someone on here suggested I separate the steering column slip joint under the hood and grease it. Fixed mine.
Is your truck included in the column recall?
Old Jun 9, 2026 | 11:11 AM
reecedowler
4wd High
As far as I am aware the recall is for 23-24. Did I will try that and report back.
Old Jun 9, 2026 | 02:10 PM
reecedowler
4wd High
Issue Update
After lubing parts of the lower steering shaft, still no remedy. Found that it is actually a noise created by rocking of the truck, when in park if i rock my truck back and forth aggressively i can get the noise to duplicate although I am unable to locate the sound while jumping up and down on my running board. Still unsure what the problem may be. Not sure if it’s a worn bearing in steering column. Something under dash. I have been unsuccessful in finding it.
File Type: mov
Old Yesterday | 07:44 AM
scraprat's Avatar
scraprat
Top Answer: 5
I believe its the clock spring. There was a rash of post about the noise in the steering wheel awhile back. Seems to be more noticeable in colder weather.
Old Yesterday | 12:27 PM
reecedowler
4wd High
The clock spring is removed, so that cannot be the culprit.
apstang50
Apr 19, 2024 07:37 PM
lowrider57
Dec 19, 2014 01:42 PM
Gangley
Sep 26, 2013 08:42 AM
euch
Bronco II
Dec 23, 2005 02:28 PM
JRSF150
2004 - 2008 F150
Dec 23, 2004 10:22 PM
