Steering wheel noise
Old Dec 22, 2021 | 08:10 PM
apstang50's Avatar
apstang50
I have a 2017 F350 with a 6.2, coming up,on a year of owning it. Sometimes after driving and I pull into my driveway or parking lot and sit with the truck running, I can hear a slight noise coming through the steering wheel/column. If I turn the steering wheel it kinda changes. It’s almost like part of the steering system may be rubbing on part of the motor and transmitting the sound. It doesn’t do it all the time, I can’t make it do it. I’ve looked and nothing it rubbing or touching. Just wondering it anyone else may have experienced anything similar.
Old Dec 22, 2021 | 08:19 PM
morehouse7's Avatar
morehouse7
The linkage has been known to wear sloppy, also make contact where it passes through into the engine compartment.
Old Dec 22, 2021 | 08:41 PM
TCNashville's Avatar
TCNashville
Could be the steering stabilizer getting squeaky. Get under the truck while running, in park of course, and have someone turn the wheels to see if you can zero in the sound.
Old Dec 22, 2021 | 10:47 PM
4wd6.7L's Avatar
4wd6.7L
Do you have adaptive steering?
Old Dec 23, 2021 | 09:01 AM
SlikWillie's Avatar
SlikWillie
Sometimes when I turn my steering wheel it sounds like there's BBs in the wheel rolling around. I can't figure that one out. I second the idea of having someone turn your wheel while you look for any rubbing or binding.
Old Dec 23, 2021 | 12:54 PM
cficare's Avatar
cficare
I believe the OP is trying to describe a noise while the truck is running and the steering wheel is stationary ... and not turning.
Old Dec 23, 2021 | 01:46 PM
4wd6.7L's Avatar
4wd6.7L
I believe you are right....after reading the OP again I see that to be the case. Not sure what would cause that kind of an issue.
Old Mar 16, 2024 | 10:06 AM
TVD's Avatar
TVD
2nd Gear
2017 F250 Steering Wheel noise
I have a 2017 Ford F250 diesel with 140K miles and am experiencing a whining noise in the steering column and it almost sounds like a short wave radio signal as I turn my steering wheel whether in park or not. any ideas what this could be?
Old Mar 16, 2024 | 10:41 AM
4wd6.7L's Avatar
4wd6.7L
The OP ghosted this thread but I do see he had another thread where an issue was found to be steering shaft related. That may or may not have been the cause of this concern too.
I'll ask you the same question, do you have adaptive steering? (OP did not)
scraprat's Avatar
scraprat
Top Answer: 5
Would be nice if posters with issues would give the solution to the problem or atleast reply with no fix found. Helps the next guy using the search function for a possible solution.
Old Mar 16, 2024 | 02:02 PM
jimzpsd's Avatar
jimzpsd
I like the "short wave radio" description....I have the same sound on my '17, small inputs or while turning a corner it will make the sound, like a dry rubber seal/grommet. I like it, its entertaining to hear.
Old Mar 16, 2024 | 03:47 PM
TVD's Avatar
TVD
2nd Gear
I do not have adaptive steering and it does sound directly related to the steering column rather than anything beyond the firewall.
Old Mar 16, 2024 | 04:36 PM
4wd6.7L's Avatar
4wd6.7L
I'm not sure what a short wave radio sounds like exactly. I have read of some having a squeeky sound when turning and it being caused by clock spring. I've been getting a sound occasionally, usually not until after driving the truck for several miles. Similar to how jimzpsd described it. I do have adaptive steering so wasn't sure if it was somehow associated with it.
Old Apr 19, 2024 | 07:37 PM
Hebejebe's Avatar
Hebejebe
i have this same issue, and adaptive steering. Currently in a super 💩show with Ford and the dealership over a replacement steering wheel..... 🤬🤬🤬
eddydata
Oct 21, 2021 12:15 PM
Gangley
Sep 26, 2013 08:42 AM
Tanner2255
Sep 30, 2012 06:41 AM
dmch2oski
Jun 11, 2009 12:52 PM
