Ticking noise from steering column
Good evening, My truck is a 2004 F150 Supercrew 5.4.
I saw mention in another post from Gmiterek indicating his truck had this issue. Ticking noise in the steering column. Mine does this to and it is annoying.
Is there a known resolution?
I am making a list of these issues so that when I take the truck in next week they can take a look at all of them.
I also have the rearend clunk\shutter at low speeds accerlerating. Sometimes turning. I see this has been covered thoroughly.
I also have a rattling coming from the front passenger door\window and also the drivers side door\window or dash. I can not tell on the drivers side for sure.
Any known issues and resolutions for this issue?
I did check the TSB section and did not see any for the ticking issue or the rattling from the front doors\windows. Thanks.
A ticking sound from the steering column when turning the wheel is most often caused by a faulty Clock Spring. The Clock Spring tensions electical brushes against electical slides so that the electric buttons on the wheel (like cruise control) work regardless of how the wheel is turned. When the Clock Spring malfunctions, it rides against the inside of the wheel itself causing a clicking sound when the wheel is turned.
Thank you Testpilot, unfortunatley this ticking noise happens almost all the time even when driving in a straight line. I know the sound you are referencing though and it does sound like that but I do not have to turn the steering wheel for it to happen. It seems to be worse if I am on a road that is not perfectly smooth. Definitely coming from the steering column though.
I have the same Ticking sound coming from I believe under the drivers side dash. It drives me crazy! Sounds almost like a relay clicking On and Off. I am taking my truck in for a leaking rear window and rear window squeek/rattle next week and hope they can figure out this Ticking under the dash at the same time. I will let you know what they find.
Read this thread, it should answer your question.
https://www.ford-trucks.com/forums/s...d.php?t=292735
Kamaikaze2b, Thank you for the link, I did not see this one. I did not have time tonight to go out and check this or the other suggestion from Mjbesen but I will have time tomorrow. I wonder if when they replaced the steering column if the part that Ultramax21 mentioned was replaced as well. I can feel the frustration that you must have felt though. I think this may be a great truck once all of the little issues are taken care of. I hope this is it because it really helps to go into the dealer with some good ideas to help the technicians out, after all these trucks are new to them as well.
As I side note I am fairly new to this board and I really do appreciate the comments and helpful suggestions made here. I will take a look tomorrow and update.
You're weclome JRS. That's the beauty of these message boards! The clicking noise has not returned since they replaced the steering column. I recommend printing out these threads and bringing them with you when you go to your appointment. Sometimes the techs are just as frustrated as you are when they can't track these noises down. Good luck and Happy Holidays!
