351w Build, speed density problems
Old Jun 6, 2026 | 07:20 PM
fishfreak101's Avatar
fishfreak101
Finally wrapping up the 88 F-150, l6 to 351w swap. For reference its my first ground-up engine build. I understand, cam profiles are very limited by the speed density system, but I can't seem to get the engine to stop idle hunting. Runs great on cold start, but after a few minutes, the vacuum as well as rpm start to bounce between 12 and 18". Here are the build specs, cam card will be attached below. Any help is appreciated-
Short block is fully stock
3 bar GT-40 heads with upgraded trickflow spring kit
new stock 19 lb fuel injectors
351w intake port matched to a 302 upper/ plenum
1.7 ratio roller rockers (will removing these put valve lift back in compatible range?)
Comp Cams Hyd. Roller
Old Jun 6, 2026 | 07:37 PM
90project5.0's Avatar
90project5.0
That cam should be causing you ZERO problems with speed density. You have a vacuum
leak or something somewhere. What ECM did you use?
Old Jun 6, 2026 | 07:59 PM
fishfreak101
a stock ecm for an 89- f-150, 351w,
smoke tested today, revealed no vacuum leaks, I'll have to check again tomorrow
Old Jun 6, 2026 | 08:11 PM
90project5.0
Turn the idle stop screw out a little to open the throttle bores, see if that smoothes it out. Did you set the timing dot to dot, degree it in, advance it?
Old Jun 6, 2026 | 08:35 PM
fishfreak101
timing was set at dot to dot, haven't touched the idle screw yet. Ignition timing is set at 12 btdc. Whats weird though and makes me thing its an issue with the speed density is that it runs flawlessly with the MAP sensor unplugged, of course at 1500 rpm though
Old Jun 6, 2026 | 09:48 PM
90project5.0
Is your map sensor for a 5.8? Not sure if they are different, but maybe? Was the computer new or used? If used, did you verify capacitors weren’t leaking?
do you have original vacuum lines? If so, no cracks in them?
Theres also this, that controlled mine.
https://lmr.com/item/LRS-9939A/1986-93-Mustang-50L-58L-Idle-Air-Control-Iac-Adjuster
Old Jun 6, 2026 | 09:55 PM
fishfreak101
https://lmr.com/item/LRS-9939A/1986-...l-Iac-Adjuster
New ecm, all new vacuum lines, iac plate installed, and map sensors are the same across the board on all 87-97.
Old Jun 6, 2026 | 10:08 PM
90project5.0
Try taking off the IAC plate and see if it will control it.
Old Jun 6, 2026 | 10:20 PM
fishfreak101
IAC plate was originally not installed, was installed to try to mitigate the issue
Old Jun 6, 2026 | 11:06 PM
90project5.0
Skip that idea then! You should absolutely get it to smooth out with the plate. If it won’t, something else is off for sure. What codes is the computer giving?
Old Yesterday | 07:22 AM
'89F2urd's Avatar
'89F2urd
remove all vacuum lines from the intake, except for the line that goes to the map sensor, until you figure out your issue. You could be leaking vacuum in any number of spots that are not at the engine, best to eliminate them while you troubleshoot.
It never ran right since first start up? Is timing 12* BTDC with the spout removed?
Old Yesterday | 09:29 AM
wwhite's Avatar
wwhite
Why? The computer will always think its set to 10*, nothing else.
Bad sensor? test it.
Old Yesterday | 09:39 AM
wwhite's Avatar
wwhite
Have you validated that the numbers card match the actual cam by measuring it?
What is your vacuum measured while idling?
Old Yesterday | 09:43 AM
wwhite's Avatar
wwhite
What computer did you install?
groundrat
15
Nov 30, 2024 03:31 PM
RWB3
Feb 11, 2023 05:40 PM
bigblocksix
Nov 29, 2006 03:45 PM
fordtrck302
Jan 1, 2006 11:04 PM
Scooter670
13
May 17, 2004 10:41 PM
