FORScan - 1995 F-250 7.3 Vehicle Speed / Overdrive Flashing Light
Old May 26, 2026 | 08:21 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Anyone definitively know if vehicle speed can be read live through FORScan? I have been trying to troubleshoot an Overdrive issue (light flashes) and replaced the vehicle speed sensor in the diff. Speedometer on the dash works, but FORScan reads speed of 0. Other live data like engine rpm and transmission position come through.
Old Yesterday | 09:11 AM
knottyrope's Avatar
knottyrope
PSOM might need to be rebuilt as it sends the signal to the PCM
Old Yesterday | 09:23 AM
bmoran4's Avatar
bmoran4
That was one of the possibilities I was considering. I am seeking a way to certainly diagnose before firing more parts cannon. If the PSOM was suspect, wouldn't the dash speedometer also be wonky?
Old Yesterday | 10:36 AM
knottyrope's Avatar
knottyrope
I have seen the dash show fine and the PCM not see the signal on here many times from a bad PSOM.
VSS ------> ABS Computer ------> PSOM ------> PCM
It could be the dash it self and that is hard to trouble shoot over the internet.
Old Yesterday | 11:10 AM
bmoran4's Avatar
bmoran4
VSS was replaced. This helped keep the dash speedometer from jumping erratically.
Is there a way to systematically test the speed signals at the ABS, PSOM, and PCM accordingly to narrow in?
Old Yesterday | 12:24 PM
knottyrope's Avatar
knottyrope
PSOM showing speed means it is working. Test the output of it to the PCM for a signal with an oscilloscope
Old Yesterday | 04:24 PM
bmoran4's Avatar
bmoran4
So the PSOM is responsible for the analog dash speedometer? And the that means that the VSS, ABS, and PSOM units are not primary suspects; that would leave the PCM? I have an older analog oscilloscope - not sure what I would need to tap to look for the speed signal. (Forgive me as I am much more intimately familiar with the simpler first generation F series trucks!)
Old Yesterday | 05:09 PM
Don Ridley's Avatar
Don Ridley
Here are wiring diagrams for the VSS signal. The VSS goes to the PSOM (red highlight). The PSOM sends it to the PCM (yellow highlight).
The speed control also gets the VSS. Maybe the speed control is affecting the signal. More likely there is a bad wire or connection.
Old Yesterday | 05:51 PM
bmoran4's Avatar
bmoran4
Where can one get those wiring diagrams?
Old Yesterday | 05:52 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
It better not. Being a 7.3L, the speed control is internal to the PCM.
Old Yesterday | 05:54 PM
Don Ridley's Avatar
Don Ridley
I should have provided the link.....
https://lemon-manuals.la/Ford/
Old Today | 07:02 AM
Talyn's Avatar
Talyn
I don't personally remember a read code for the VSS in the OBS models. In the Super duty stuff, there is 100's more sensors you can pull from.
I have no idea where my read code chart is though. So I can't look and see if it's on there.
Maybe it was.
But ...
How the fk would the PCM not see it, but the dash see it??? that makes no sense.
Old Today | 08:31 AM
Don Ridley's Avatar
Don Ridley
The speed signal is created by the PSOM in the instrument cluster. Then the speed signal is sent to the PCM.
umurillo1
Apr 21, 2026 09:49 AM
Steve Harris
Dec 24, 2021 09:29 AM
Handegard
Large Truck
Dec 14, 2010 09:55 AM
fordfanatic1337
15
Apr 4, 2006 11:37 AM
hunterfisherman
Oct 9, 2004 09:43 PM
