Speed bouncing and overdrive light flashing
Old Apr 21, 2026 | 08:59 AM
umurillo1's Avatar
umurillo1
8th Gear
Has anyone had this problem?needed on my dash is bouncing and overdrive light keeps flashing
Old Apr 21, 2026 | 09:08 AM
knottyrope's Avatar
knottyrope
Yes many have.
could be any one of the following
VSS failing, Metal in diff, VSS wiring, PSOM issue, dask cold solder joint or even an alt with a bad diode can do it.
Old Apr 21, 2026 | 09:49 AM
umurillo1's Avatar
umurillo1
8th Gear
Thanks will check these out
Farmer Brad
Feb 21, 2024 06:01 PM
tomo805
Nov 20, 2011 08:15 AM
blackwidowrealtree
Aug 12, 2011 05:47 PM
Bigger B
Electrical Systems/Wiring
Jun 2, 2004 05:29 PM
ladani
1997 - 2003 F150
Jul 12, 2001 03:54 AM
